* * * * * 3 votes
Bush Hog JBI Diesel Repower (Hogzilla)
792 replies to this topic
#256 Meangreen OFFLINE
Meangreen
  • 94 Thanks
  • 300 posts
Posted March 24, 2011 - 08:12 AM
Passing with the plow down is tough skill to master.
The guy in front was pulling a 12" plow and walking right on with it! In the video at the first of the tread I was trying high range to see how it would plow, 430 said NO WAY!! Low range it did great. Some day I would like to own a 12" plow.
#257 MH81 OFFLINE
  • 29,978 Thanks
Posted March 24, 2011 - 07:37 PM
Mounted my deck so the JD will only get mowing duty for quite some time now.
Sounds a little like someone is backing out...
#258 olcowhand ONLINE
  • 42,896 Thanks
  • 31,939 posts
Posted March 24, 2011 - 08:28 PM
Told ya he's skeered! :rofl2:
#259 massey driver ONLINE
massey driver
  • 1,510 Thanks
  • 1,598 posts
Posted March 25, 2011 - 07:14 AM
The guy in front was pulling a 12" plow Some day I would like to own a 12" plow.
Hey Dan it almost sounds like a hint !!!I just gave you a idea as too what to get him for his Birthday. LOL Larry
#260 olcowhand ONLINE
  • 42,896 Thanks
  • 31,939 posts
Posted March 25, 2011 - 08:59 AM
Well, I'd have to come across two 12" plows, cause the 1st I see will be MINE! LOL
#261 Meangreen OFFLINE
Meangreen
  • 94 Thanks
  • 300 posts
Posted March 25, 2011 - 10:07 AM
Shhhhhh, Don't tell Daniel but when I raise my deck it will give me extra weight to deal with his extra HP. Remember not to tell Daniel, he will never figure out whats going on!!:beerchug:
#262 olcowhand ONLINE
  • 42,896 Thanks
  • 31,939 posts
Posted March 25, 2011 - 10:10 AM
I gots an original deck for the JB too! LOL
#263 olcowhand ONLINE
  • 42,896 Thanks
  • 31,939 posts
Posted March 26, 2011 - 10:50 AM
Working on readying the NOS diff & hydro for the JB. Got the Massey 1655 hubs modded & mounted on the JB diff axles. Gotta cut a new hydro to diff gasket, then mount together. Need to pick up a new hydro filter. Then it'll be time for the swap. Sometime this coming week, the JB should be strong again!
#264 olcowhand ONLINE
  • 42,896 Thanks
  • 31,939 posts
Posted March 26, 2011 - 03:12 PM
Between milkings and getting calf & momma in, I got the NOS hydro mounted to the NOS differential & the hubs mounted on axles. With a little luck, it all might be under the JB tomorrow for testing. I'll have to use the old hydro filter if I do, unless I have something that will fit it. I have a couple new hydraulic filters that one may fit till I can get a correct one.
#265 olcowhand ONLINE
  • 42,896 Thanks
  • 31,939 posts
Posted March 27, 2011 - 02:18 PM
The diesel JB pulls strong again! Got the hydro/diff swap finished. Lots stronger now, and power steering now works fine. When the hydro started getting weak, the cooler up front wasn't even warm, but the hydro was HOT, so the charge pump had failed. I've just been driving it around today with no hard pull, but the hydro is warm, and the cooler is equally warm on the inlet too, so oil is flowing through the cooler.
Need to take the 3pt lift cylinder apart & put in new seals. The guy I got the tractor from said he just had his brother rebuild the cylinder.....bro didn't do it right though. It's keeping the top of the diff wet with oil.
Looking good for plow day at Vevay, IN on April 16th!
#266 olcowhand ONLINE
  • 42,896 Thanks
  • 31,939 posts
Posted March 27, 2011 - 05:14 PM
Went ahead & pulled the lift cylinder apart. The shaft end seal plug's o-ring was torn in-two, plus the o-ring that seals on the shaft was too small and not sealing good on the shaft. NO leaks now and hope it stays that way. Everything seems great, but before Vevay plow day, I wanna put a good load on it for a while to be double sure. May make a heavy drag & weight it down. Here's a pic of the NOS hydro & diff installed.
#267 NUTNDUN OFFLINE
  • 10,351 Thanks
Posted March 27, 2011 - 05:25 PM
Awesome news Daniel. Glad to hear you got her fixed up and got the lift cylinder fixed too :D
#268 olcowhand ONLINE
  • 42,896 Thanks
  • 31,939 posts
Posted March 27, 2011 - 05:38 PM
Both o-rings I put in are a bit small, cross section wise, but stopped the leak just the same. If it starts leaking again, I'll have to go to "General Rubber & Plastics" & get thicker o-rings.
#269 MH81 OFFLINE
  • 29,978 Thanks
Posted March 28, 2011 - 04:15 PM
May I suggest using a green tractor for this purpose?
#270 olcowhand ONLINE
  • 42,896 Thanks
  • 31,939 posts
Posted March 28, 2011 - 04:50 PM
Great idea Alan. meangreen wants to "hook em" anyway, so that would be a good way to warm my hydro, dragging that JD430 backwards for an hour or so!:bigrofl::bigrofl:...........:poke:...........:smilewink::smilewink:
