* * * * * 5 votes
Lets Call It Db2
363 replies to this topic
#76 MH81 OFFLINE
  • 29,979 Thanks
Posted March 30, 2014 - 08:22 AM
Just now got caught up. Bummer on the angle in the box, you were making such good headway too.
Don't let it slow you down...
  • Chris11 said thank you
#77 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted March 30, 2014 - 08:54 AM
No ill get on that Monday. I have to pull tranny apart too. Its a 4 speed and has a dodge dart carrier in it.
  • trowel said thank you
#78 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted March 30, 2014 - 09:50 AM
Today wasn't a good day. I did some math and Things didn't work out to good. I almost scraped the hole thing. When I did my drive line there was some thing wrong. And I found it. But now to keep it going I have to build a new drop box. Some one machined the drop box on an angle. The drive shaft wasn't level with tran . I couldn't get the engine any lower. so the more I looked at it I have to shorten the drop box by .750 so my drive shaft is straight. Ill start on that Monday. I wanted to get motor plate mounts welded in but I cant till this is done now. If its not right on the money I wont build i
What way was the shaft running off ? Some trans are set in at an angle upwards and the motor tipped back to true them up and not have a bind.  Was the plate true in the old frame ?
#79 bgkid2966 OFFLINE
bgkid2966
  • 1,412 Thanks
  • 1,331 posts
Posted March 30, 2014 - 10:02 AM
Wow! This is an awesome build! Thank you for sharing your talents with us! I look forward to your installments and photos!
Geno
#80 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted March 30, 2014 - 11:29 AM
I wish it was like that. They had to do it in the old frame because nothing was straight. It was binding on the shaft. I got it worked out now. I just found a nice block of aluminum to make it out of. I will post pictures of that too.  Duane you coming out next week?
#81 Guest_Fluid_*
Guest_Fluid_*
  • Guests
Posted March 30, 2014 - 11:58 AM
Today wasn't a good day. I did some math and Things didn't work out to good. I almost scraped the hole thing. When I did my drive line there was some thing wrong. And I found it. But now to keep it going I have to build a new drop box. Some one machined the drop box on an angle. The drive shaft wasn't level with tran . I couldn't get the engine any lower. so the more I looked at it I have to shorten the drop box by .750 so my drive shaft is straight. Ill start on that Monday. I wanted to get motor plate mounts welded in but I cant till this is done now. If its not right on the money I wont build it.
I'm sorry to hear about your set back Chris, but don't you dare scrape all that work you did. Theres a reason for everything, we just don't see it until later on. You'll figure it all out in time man.  Nothing in life is perfect, but your work is damn close.  Keep it coming Chris.   Glenn
#82 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted March 30, 2014 - 12:08 PM
I feel better about making a new box. That way I know its right.  Thank you guys for all the nice comments.
#83 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted March 30, 2014 - 02:44 PM
That's the plan Talked to Brian yesterday about stopping to pick that hood up if you want us to
#84 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted March 30, 2014 - 04:45 PM
If its on your way.
#85 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted April 01, 2014 - 06:00 PM
Ok started the drop box,
  • trowel and bgkid2966 have said thanks
#86 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted April 01, 2014 - 06:02 PM
Made steering column today too.
  • trowel, Cvans, bgkid2966 and 1 other said thanks
#87 IamSherwood OFFLINE
  • 8,395 Thanks
Posted April 01, 2014 - 07:14 PM
You where multi-tasking.
Turning the column, while the mill chewed away. :thumbs:
#88 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted April 03, 2014 - 07:39 PM
Drop box started and I made up a center bearing support for dive shaft.
  • IamSherwood, trowel and bgkid2966 have said thanks
#89 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted April 03, 2014 - 07:41 PM
Maybe I shouldn't be posting so much I feel like im taking over the pulling section. Please let me know
#90 Guest_Fluid_*
Guest_Fluid_*
  • Guests
Posted April 03, 2014 - 09:23 PM
Are you joking or what? I can't speak for everyone, but I like your posts. Its cool to watch you take a block of metal and turn it into something. I'm learning  from your pictures and stuff.   So you keep up the posts, plus this is your build anyways.  Start to finish, keep it coming Chris
  • Chris11, IamSherwood, trowel and 1 other said thanks
