* * * * * 5 votes
Lets Call It Db2
363 replies to this topic
#136 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted July 30, 2014 - 09:04 PM
The rack is made for a Jr Dragster. im working on the side panels but I am working the hood more to make it look longer. and lower.
#137 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted August 15, 2014 - 07:17 PM
some new pics, its a roller now. got brake lever done, tie rods and fitting the sheet metal before its made in to carbon fiber. Im trying some new wheels not sure if I like them.
  • KennyP, bgkid2966 and backwoods have said thanks
#138 KennyP ONLINE
  • 41,023 Thanks
  • 47,165 posts
Posted August 15, 2014 - 07:21 PM
Good looking ride there!
  • Chris11 said thank you
#139 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted August 15, 2014 - 08:37 PM
more pics
  • bgkid2966 and Dieselcubmike have said thanks
#140 bgkid2966 OFFLINE
bgkid2966
  • 1,412 Thanks
  • 1,331 posts
Posted August 16, 2014 - 08:11 AM
Great looking puller! Great work!
Geno
#141 MH81 OFFLINE
  • 29,979 Thanks
Posted August 16, 2014 - 12:03 PM
She's really coming together. Good looking tractor!
#142 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted August 18, 2014 - 05:25 PM
Looks great so far chris. Really like how those shifters from kerber look on there cant wait to grab myself a set :D
#143 lesmeister OFFLINE
lesmeister
  • 187 Thanks
  • 172 posts
Posted August 18, 2014 - 08:43 PM
Great fab work, looks awesome.
#144 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted August 22, 2014 - 09:06 PM
Heres some detailed pictures of the steering rack with control arms, Because I mounted rack so that the shaft is under motor plate the only way I could get it passed the engine. The rack steers backwards so to make it steer right I had to make a drop reversing box, This helps with shaft support, makes the angle of the u joints  better. and reverses  direction of the rack. I had an old oil pump that I took the gears out of cut one in half machined the shafts for them. next I machined a box with needle bearings pressed in.
  • bgkid2966 and T Guiles have said thanks
#145 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted August 22, 2014 - 09:11 PM
After getting the case bolted together. I lightened it up some , you can see in pictures where its going to mount. It works great no play in the wheel at all.
  • MH81, bgkid2966 and T Guiles have said thanks
#146 T Guiles OFFLINE
T Guiles
  • 953 Thanks
  • 749 posts
Posted August 22, 2014 - 11:59 PM
You sir are a true artists... I am in awe of of your work. Thank you for the pics and the updates, I love it. Have you decided on a color or am I getting too far ahead. I am hooked and will be drooling every tie I'm on thank's
#147 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted August 23, 2014 - 07:04 AM
Thank you, I have more fun building them then anything. Im thinking of a bright red. or I may go back a gold.
#148 bgkid2966 OFFLINE
bgkid2966
  • 1,412 Thanks
  • 1,331 posts
Posted August 23, 2014 - 07:35 AM
Just AWESOME!!! :thumbs:  :thumbs:
Geno
#149 T Guiles OFFLINE
T Guiles
  • 953 Thanks
  • 749 posts
Posted August 24, 2014 - 10:42 PM
I really like the gold you had on it before. It was really different and classy looking, but I'm sure what ever you decide it'll be sharp
#150 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted September 05, 2014 - 07:10 PM
Im starting to work on my engine block. I machined the flanges of intake and exhaust. Now im boring out the block for the 4.125 piston. I will get to do intake port next.
  • T Guiles said thank you
