Integrated Power Module Repair
1 reply to this topic
#1 Sawdust OFFLINE
Sawdust
  • 6,010 Thanks
  • 3,490 posts
Posted March 15, 2014 - 10:23 AM
My son has a 2002 Dodge Ram 1500 Crew Cab pickup. This is considered the 3rd generation of the new & improved Dodge trucks back in 2002. All the parking lights stopped working. Obvious it's not the bulbs so I checked all the routine possibilities with no solution. I went online & found another issue with the 3rd gen trucks. On the bottom of the IPM ( fuse box) they put air vent holes to prevent moisture buildup. These same holes aloud this moisture along with road dirt to enter & corrode the circuit board. This IPM used sells for $350. or new at dealer up to $700. & another $500-$700. for labor. They are a few quick but not safe fixes like bypassing the relay or running a switched wire to the cab when you need lights. I found another solution of repairing the circuit board & once again thank God for the info on the internet. Instead of telling you what I done I'll just include the link because it would be easier to follow. I will show some pics of my successful repair.
It looks worse that it really is but make sure you label the plugs because it looks like a few would enterchange.
The IPM
The copper band corroded to the point a small section about 1/4" was totally gone
I soldered a small piece of copper wire to bridge the gap & also covered with clear silicone
You can see the vent holes next to the ports & the green is the naked circuit board I also covered these with silicone
I know like many of us want to save money by doing our own repairs. I have always done my own so I wanted to share this & I hope it helps someone or educates another to pass on the info. Here is the YouTube link I used.
#2 JDBrian OFFLINE
  • 9,644 Thanks
  • 14,158 posts
Posted March 15, 2014 - 02:31 PM
That's a pretty easy repair if you know where to look for the problem. It's ridiculous that a dealer would charge 5-700 labor to install a new board.
  • Sawdust said thank you
