Ok Guys I Need Ideas - 4 Wheel Wagon
22 replies to this topic
#1 petrj6 OFFLINE
petrj6
  • 4,084 Thanks
  • 2,369 posts
Posted March 13, 2014 - 08:27 PM
:camera:   I have seen 4 wheel wagons here in the past, tried a search and nothing good came up.  I have a few allis chalmers b series garden tractors and want to build a 4 wheel wagon for them.  It has to be the type where the tires turn not the axle for stability but otherwise I am open to ideas.   I am going to get a mid 80's gt that is scrap, I will pull the front axle out of that for starters but the rest is going to be custom.
  SHOW ME PICS :camera:  I need ideas!!!!   I am thinking of a 1/4 size hay wagon.   Attached is a pic of the daughters pedal tractor, mine all look the same just yellow.
  • trowel, chris m and boyscout862 have said thanks
#2 TAHOE OFFLINE
TAHOE
  • 8,186 Thanks
  • 5,765 posts
Posted March 13, 2014 - 08:46 PM
http://www.mytractor...ad.php?t=538129
http://www.mytractor...5945&highlight=
http://www.ihcubcade...html?1222874187
Don is a member on here too.
http://www.mytractor...ad.php?t=471650
  • Alc and chris m have said thanks
#3 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Oh, i like the lawn tractor axle idea ! turn the axle around and weld a tong onto the steering rod.
You could use angle iron box frame with wood cross boards, use LT front wheels on the back also.
#4 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 13, 2014 - 09:15 PM
How about this :
http://www.google.co...394849659911432
  • Alc, chris m and boyscout862 have said thanks
#5 MH81 OFFLINE
Posted March 14, 2014 - 04:10 AM
Here is Kenny's
http://gardentractor...-4-wheel-wagon/
Wheel Horse made an OEM 4 wheel unit.
http://gardentractor...-1359905109.jpg
Don made one with pics at the following links
http://gardentractor...-17#entry179503 http://gardentractor...-17#entry179933 http://gardentractor...-18#entry180189
Northern makes a running gear with 4 wheel steering. http://www.northernt...ailers-_-125750
Someone on CL used a set to make a dump trailer. http://gardentractor...-1378373325.jpg
Member grnspot110 Made one http://gardentractor...ts/#entry400372 http://gardentractor...e-3#entry185768
KWJ427 made a gravity wagon http://gardentractor...-gravity-wagon/
Member Robert Webb made one http://gardentractor...ld/#entry387584
Member Simplicity Swede has some pics in a photobucket http://s1172.photobu...s?sort=3&page=1
Dieselcowboy made one, pics start here http://gardentractor...e-2#entry183647
KC9KAS found these pics
http://gardentractor...e-4#entry185808
  • Alc, KennyP, trowel and 1 other said thanks
#6 KennyP OFFLINE
  • 40,224 Thanks
  • 46,806 posts
Posted March 14, 2014 - 05:28 AM
The one I built has the steering like you are wanting. I used go-cart front spindles.
  • MH81, Alc, Chris11 and 5 others have said thanks
#7 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted March 14, 2014 - 06:29 AM
That's a great looking wagon Kenny. Nice job looks like it would do a lot of work.
#8 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted March 14, 2014 - 06:47 AM
I will post a few of my wagon pics after work tonight or in the morning.
#9 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted March 14, 2014 - 02:26 PM
pics of my wagon. every wagon I seen was a flat bed hay rack , so I made a barge box for hauling grain.
#10 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted March 14, 2014 - 03:38 PM
25z1l3q.jpgif i build one itll be like that
#11 petrj6 OFFLINE
petrj6
  • 4,084 Thanks
  • 2,369 posts
Posted March 14, 2014 - 06:08 PM
   I really like the one Kenny made,  I think I will go that route with the removable sides,  that way I can have different sides.  Now to start gathering parts and supply's.  Thank's guy's :urock:
  • KennyP and trowel have said thanks
#12 KennyP OFFLINE
  • 40,224 Thanks
  • 46,806 posts
Posted March 15, 2014 - 05:59 AM
One thing I found that I want to change is the amount of pivot I left in the front axle. It is too much, only needs about half.
#13 grnspot110 OFFLINE
grnspot110
  • 4,295 Thanks
  • 2,684 posts
Posted March 15, 2014 - 06:38 AM
Mine is smaller, approximately 1/3rd scale JD model #953 farm wagon:
I built it for shows to haul a JD pedal fire truck:
Lowell
#14 KennyP OFFLINE
  • 40,224 Thanks
  • 46,806 posts
Posted March 15, 2014 - 06:45 AM
Wouldn't be hard to make one a little larger, Lowell. There are some nice wagons in this thread! Thanks folks!
#15 Walkinman1 ONLINE
Walkinman1
  • 769 Thanks
  • 586 posts
Posted March 15, 2014 - 06:54 AM
So you're saying it actually turns too far? I can't quite wrap my mind around that concept, it seems like more would almost always be better.
