Shift Pattern ?
3 replies to this topic
#1 SNUFFY OFFLINE
SNUFFY
  • 188 Thanks
  • 272 posts
Posted March 13, 2014 - 12:52 PM
I know I`m hoping....somebody might know for sure what the shift pattern would be on this true grey market Shibaura 14/1400. It does appear to be different from all the Ford Trannys I`m seeing in the Ford service manual. I`ve not really had too much time to fool with it so far, but it acts like a 4-speed plus reverse. R is all the way to right and down (back). and the lowest  (1rst) seems to be to the right and up. The other three are a little bit of a crap shoot. The ratios are really close together. Just hoping someone might actually have had one of these things .
#2 trowel OFFLINE
trowel
    Summer.
  • 4847 Thanks
  • 4535 posts
Posted March 13, 2014 - 02:00 PM
Just like mines, if i remember corectly,...3 rd is to the left next to reverce, above that is second and vice vera,..
High and low is to the right of the gearcase, forward for low, back for high.
  • SNUFFY said thank you
#3 JD DANNELS OFFLINE
JD DANNELS
  • 3791 Thanks
  • 3907 posts
Posted March 13, 2014 - 02:48 PM
I'm not familiar with that model so can't help with the shift patern.
Mine has like two transmitions in line. The first with 4 ranges and the second with 3 speeds and reverse.
The 3 speed has 1st on the right and reverse on the left , Forward 3rd on left and 2nd on right.
  • trowel and SNUFFY have said thanks
#4 SNUFFY OFFLINE
SNUFFY
  • 188 Thanks
  • 272 posts
Posted March 14, 2014 - 01:02 PM
thanks guys...guy on another forum suggested marking a tire and counting revolutions at same RPM....should be easy in low range. Sounds fairly easy. Then a Sharpie on the shiny metal where the pattern used to be :thumbs:
