Spark Plug Leads?
5 replies to this topic
#1 IamSherwood OFFLINE
  • 8,391 Thanks
Posted March 12, 2014 - 11:27 PM
What do you guys do?
Buy pre-made leads? Where?
Make up your own?
If so, what materials do you use/prefer ?
Boots, ends, wire?
I find that a lot of the aftermarket stuff is just
so cheap looking, and am looking for a supply
of quality parts. It such an important part, but
so often I see how people have cobbled something
together, in an effort to get a spark, and then leave
it that way.
Primarily, I asking about a lead, for say a "K" series Kohler.
  • A.C.T. said thank you
#2 boyscout862 ONLINE
  • 12,839 Thanks
  • 9,162 posts
Posted March 13, 2014 - 12:39 AM
I use automotive solid copper wire from a roll I bought years ago. Most auto stores have them. I sometimes use old style auto wires(1950s) and modify them. Good Luck, Rick
  • Alc and trowel have said thanks
#3 powerking56 OFFLINE
powerking56
    Collector of stuff
  • 909 Thanks
  • 1,805 posts
Posted March 13, 2014 - 05:57 AM
For my earlier motors I make my own with bulk wire and fittings/ends I get from a couple suppliers that are at several of the shows I go to.
I try and scrounge spark plug boots whenever I can find ones that are not molded on.
  • trowel said thank you
#4 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted March 13, 2014 - 06:32 AM
I make my own leads.  I use good spark plug wire and crimp on spark plug terminals to get 'er done.
I always use boots.  Don't shortcut there or else you'll corrode the coil lead.  Rajah terminals are good quality terminals that take the heating and cooling and high electricity well.
Kohler leads can tolerate resister plug wire, most other type of magnetos, flywheel style in particular, don't like it.
Ben W.
#5 Sparky OFFLINE
Sparky
  • 1,298 Thanks
  • 1,892 posts
Posted March 13, 2014 - 08:00 AM
Using solid or stranded copper wire used to generate television interference complaint once upon a time . But as always the quality of the insulation and whether the ignition on computer controlled ignition will tolerate the lack of built in resistance  in copper is a factor  .
  If it won't disturb the moose - go for it  Will  .
  • trowel and boyscout862 have said thanks
#6 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted March 13, 2014 - 08:45 AM
Mig welder leads, arch welder leads are too thick, usually can buy at hardware store by the foot, the ends i usually reuse the originals, the boot, depending on the year and MFG can still be bought new.
I stock piled NOS boots for the 50's and 60's.
Everything else the guys above mentioned.
