What Is This For?
cultivator
11 replies to this topic
  • 2,348 Thanks
  • 1,502 posts
Posted March 12, 2014 - 05:25 PM
I've started repainting this cultivator.  While I was disassembling it, I noticed this piece, which appears to serve no useful purpose.  It doesn't move & isn't connected to anything else.  That said, it looks original.  Any idea what it is for?
  • trowel said thank you
#2 DougT OFFLINE
DougT
    Dog Approved
  • 7,112 Thanks
  • 5,077 posts
Posted March 12, 2014 - 05:30 PM
It looks like a way to adjust depth. Are there any trailing wheels on it? Maybe it should have one there?
  • trowel, New.Canadian.DB.Owner and superaben have said thanks
#3 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted March 12, 2014 - 05:49 PM
Depth wheel make sense.  There isn't one on it anywhere else.
#4 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 12, 2014 - 06:08 PM
Furrow plow, with the 3 holes it is adjustible.
Depth wheels were usually on the back due to the hitch, if horse drawn depth wheel on the hitch.
Edited by trowel, March 12, 2014 - 06:10 PM.
#5 petrj6 OFFLINE
petrj6
  • 4,084 Thanks
  • 2,369 posts
Posted March 12, 2014 - 06:46 PM
:ditto:
#6 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted March 12, 2014 - 07:17 PM
at one time a lot of walk-behind tractors had a handle or even some linkage that would let you steer the vator unit, separately from the tractor handles. Don't know if this applies to yours but it could have had something similar.
#7 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,139 posts
Posted March 12, 2014 - 07:32 PM
Most units don't have down pressure, you can mount a seat on that spot and park a FAT CAT on it.
  • trowel and New.Canadian.DB.Owner have said thanks
#8 DougT OFFLINE
DougT
    Dog Approved
  • 7,112 Thanks
  • 5,077 posts
Posted March 12, 2014 - 08:36 PM
Is there any kind of an implement lift on the handle bars that would connect to that with a rod to control depth? You'de have to have some way to transport it.
#9 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 12, 2014 - 08:53 PM
Thought about that, i know what you are thinking, i think for Simples's or Speedex's early walkers had a single handle, that was a differnt set up for different vator'.
Simplicity did that with the early walkers, the bracket was on top of the frame, it was not like new canada's, see how it bends inline with the vator beam, my Planet Jr. and simple walker VA (sold it) has that also for the furrower plow.
#10 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted March 13, 2014 - 10:30 AM
Is this the type of furrower plow you mean?
#11 DougT OFFLINE
DougT
    Dog Approved
  • 7,112 Thanks
  • 5,077 posts
Posted March 13, 2014 - 11:25 AM
If you look at the picturs of Will's Simplicity in post 20 here http://gardentractor...e-2#entry428692 you can see a trailing wheel at the back. You must be missing that?
#12 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 13, 2014 - 05:34 PM
The one on the left is for Troy Bilt, the one on the right is more like it.
Im thinking that too, it could even be the hard rubber type, have seen those.
Also tagged with one or more of these keywords: cultivator
