Where To Get Tiller Tine Shafts?
8 replies to this topic
#1 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 627 posts
Posted March 12, 2014 - 01:42 PM
Is there a place to get the shafts that the tines attach to on a simplicity/allis tiller??
#2 boyscout862 OFFLINE
  • 10,350 Thanks
  • 7,838 posts
Posted March 12, 2014 - 03:06 PM
Try our sponsors. Then check www.simpletractors.com for their sponsors. Good Luck, Rick
#3 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 627 posts
Posted March 12, 2014 - 04:06 PM
Oh man, I found them on PartsTree and Good Lord those things are expensive :biting_nails:
#4 MH81 ONLINE
  • 28,390 Thanks
  • 29,103 posts
Posted March 12, 2014 - 05:00 PM
I had roughly the same reaction. I am assuming you are talking about the tubes and square pieces.
I ended up having nothing to loose and did it the farmer way. You can read about its resurrection starting here: http://gardentractor...ge-2#entry21256
  • trowel said thank you
#5 petrj6 OFFLINE
petrj6
  • 3,929 Thanks
  • 2,299 posts
Posted March 12, 2014 - 06:57 PM
   I re-built mine completely after I broke one of the output shafts in the garden trying to root out a rock :wallbanging:     NOT RECOMENDED.  If you are handy it is not to bad to re-build the shafts, just find the rite size pipes, weld them in place and re-drill the holes.  viola done.
   Got any pics of the damage???????//
#6 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 627 posts
Posted March 13, 2014 - 08:41 AM
I haven't taken pictures of the damage yet but I will. If I could find some heavy wall pipe that is the samll sizes of both ends I guess I could cut the ends off and reweld pieces back in place then redrill the holes. One side the outer shaft /tube is wallered out on the inside of the tube along with the holes that the bolt goes thru to hold the outer tube to the inner pipe together. :(
#7 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 627 posts
Posted March 13, 2014 - 08:51 AM
MH81, yours appears to be in pretty much in the same shape as mine. However, the inner most shaft that the longer outter shaft bolt to are wallered out as well where the bolt goes thru. :wallbanging:
#8 petrj6 OFFLINE
petrj6
  • 3,929 Thanks
  • 2,299 posts
Posted March 16, 2014 - 06:51 PM
   If I remember correctly I had to get a piece of super heavy wall pipe then drill it out for the rite size bore, cut to length, weld in place, drill hole in one side then put it on the tiller and drilled thru so the hole comes out rite on the other side.  I may even have a piece of the pipe left around, if you need it let me know I will look.
#9 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 627 posts
Posted March 17, 2014 - 09:30 AM
petrj6, if you wouldn't mind would you look around and see if you still have a piece of that pipe??
