1971 Case 444 Restoring
case 444 electrical groung wiring
4 replies to this topic
#1 pancakimo OFFLINE
pancakimo
  • 2 posts
Posted March 11, 2014 - 05:22 PM
I am almost done putting back together my 1971 case 444.  She is running great but it will start while in gear and with attachment lever engaged.  All the wiring is new and done to the manual but I'm thinking I might have some grounding problems which I don't know much about.  Anyone know of a diagram that shows the ground wires going to the attachment lever and shifter? I would appreciate any input. Thank
#2 KC9KAS ONLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted March 11, 2014 - 06:41 PM
I can't help other than telling you to check any/all safety switches....And maybe it doesn't have any due to it being a 1971.
But I can say, :welcometogttalk:  and :wewantpics:
#3 Newpaws493 OFFLINE
Newpaws493
  • 1,368 Thanks
  • 1,811 posts
Posted March 11, 2014 - 06:43 PM
:welcometogttalk:  I'm not to familiar with your machine but you'll find helpful info in the manuals section Here .
I did see the 444 listed. Guys more in the know will likely be stoppin by too. Goodluck and Enjoy the site!
#4 pancakimo OFFLINE
pancakimo
  • 2 posts
Posted March 11, 2014 - 06:48 PM
Thank you, glad to be her, The wire goes to a safety switch then up to the neutral spot on the dash at the shifter but it seems like it is grounding out to the body first. I'll post pics when I can.  Nice quote by the way
#5 gopher OFFLINE
gopher
  • 763 Thanks
  • 757 posts
Posted March 11, 2014 - 08:56 PM
I think you have a short grounding the wire from solenoid before the pto switch.
Also tagged with one or more of these keywords: case, 444, electrical, groung, wiring
