Sears 3 Point Hitch Questions
hitch 3 point sears
19 replies to this topic
#16 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted March 13, 2014 - 03:58 PM
The extension with the 3" shorter arms would make it really nice.
maybe I didn't say it correctly. The extension bolts to the handle you pull on, not the arm. It adds almost 18" to the handel.  There were also some tiny braket that bolted to the lift arms, that give you a higher lift for things like the seeder. The best 3pts lift the attachment straight up off the ground.
  • HowardsMF155 said thank you
#17 MH81 OFFLINE
Posted March 13, 2014 - 04:27 PM
Oh, no you said it right, I understood perfectly.
They made the handle extension and also shorter arms for the 3 point. The shorter arms came with some tillers and were 3" shorter than the regular ones.
I also agree with the "straight up" statement. I see a lot of toplinks set short and the implement leaning way forward. You expect a little lean, but not to much.
  • HowardsMF155 and Lauber1 have said thanks
#18 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted March 13, 2014 - 05:33 PM
Wow, I forgot completely about the short arms for tillers. all the pre 65 units came with short lift arm, as a part of the tiller. You had to remove your normal arms and top link, then use the ones that came with the tiller. There was also the odd setup for the sprayer where you only used a part of the 3pt, and the hayrake where you have to remove the 3pt stuff completely.
  • MH81 and HowardsMF155 have said thanks
#19 TX_Dj OFFLINE
TX_Dj
  • 141 Thanks
  • 84 posts
Posted March 14, 2014 - 12:33 PM
Was that also true for later 3PT's and later tillers?
I ask because when I first tried out my tiller, it seemed to "walk and wobble" a lot more than I expected, and I wonder if that's the point of the shorter arms.
#20 TAHOE OFFLINE
TAHOE
  • 7,950 Thanks
  • 5,667 posts
Posted March 14, 2014 - 12:51 PM
Could be. I think the shorter arms brought weight closer to tractor to make it easier to lift.
When I was only 8 or 9 yrs old, I was at my uncle and helped him unpack and put together a 3pt rotospader rear tiller for his Sears.... had I only known what it was and I would be a sears guy 35 yrs later.
  • MH81, searstractorfan and TX_Dj have said thanks
Also tagged with one or more of these keywords: hitch, 3 point, sears
