For Sale
Gravely Tractor And Garden Attachments
1 reply to this topic
#1 IWLBCNU OFFLINE
IWLBCNU
  • 123 Thanks
  • 160 posts
Posted March 11, 2014 - 05:58 AM
Located in Central VA
1962 Gravely LI with governor, remote PTO and electric start. Includes the rotary cultivator and rotary plow. This is a barn find, tractor starts right up, but smokes very badly. Rings are either stuck or need replacing. Otherwise everything works as should. It is missing the air cleaner assembly. Would make a great restoration candidate, or put back to work. $400
I also have a 30" deck, 2 40" decks, and part of a sickle mower to sell seperate.
Contact iwlbcnu@hotmail.com
  • superaben said thank you
#2 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted March 11, 2014 - 09:35 PM
I've got a good air cleaner (dry type) assembly if someone needs it to make a complete tractor.
That tractor has all the goodies you want on an L except a Swiftamatic low range.  However an LI is the best tractor to keep up with if you plan to use it and don't want to spend the Swiftamatic dollars.
Ben W.
  • IWLBCNU said thank you
