How Much Hp Can A Peerless 2300 Withstand?
4 replies to this topic
#1 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,440 Thanks
  • 1,860 posts
Posted March 10, 2014 - 03:48 PM
I want to make a Jacobsen with a Peerless 2300 into a "sleeper" to pull with. My question is how much hp can a Peerless withstand safely. It'd be just for fun so I don't want to have to fix the rearend.
#2 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted March 10, 2014 - 03:53 PM
Not sure, but there are Peerless manuals in the manuals section that might give you some specs. One clue is to look at the tractors that have used that rear end. I think JD used it in the 200's up to the 16hp k341 powered 216.  Not sure if it was ever used in a twin cylinder tractor. My worry would be more about the condition of that individual transaxle. If it is worn and has loose bearings etc it won't hold up to pulling for long.
#3 VintageIronCollector OFFLINE
  • 1,440 Thanks
  • 1,860 posts
Posted March 10, 2014 - 05:31 PM
Tranny needs a new rebuild eventually but I'm worried about gears, etc.(pretty much expensive stuff and unavailable stuff)
#4 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted March 10, 2014 - 07:18 PM
I got a 18 hp v twin with a peerless 2300 needs 3rd and 4th gear but it holding up i feel its not to strong but ill see  got another one im putting in i think itll take it after a rebuild
#5 truckintyler OFFLINE
truckintyler
  • 90 Thanks
  • 63 posts
Posted March 11, 2014 - 07:09 AM
didnt sears use them with the 19.9 hp onan engines?
