Mf 7
21 replies to this topic
#16 Stoneman OFFLINE
Stoneman
    Masseyholic
  • 26 Thanks
  • 157 posts
Posted February 16, 2011 - 07:35 PM
Ya, it looked like someone had rplaced the rod before i did. the govoner gear had no theeth on it when i first took the enginge aparp. it looked like it had over reved. i put it back together the way i took it apart, and i don't remember seeing any "cap". Thanks for the help!!
#17 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted February 16, 2011 - 08:21 PM
It may not be an actual cap, but those flyweights push something out to push against the gov arm. Better look at that exploded view to check me tho.
#18 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1082 posts
Posted February 16, 2011 - 08:38 PM
Seems like you can't buy gum for $250 anymore so I would say you got a great deal!
#19 Stoneman OFFLINE
Stoneman
    Masseyholic
  • 26 Thanks
  • 157 posts
Posted March 05, 2011 - 02:09 PM
Well it turns out that the bolt at the base of the govenor arm was loose! after tightening it up it seems to run fine! But after it sitting over the week i went to start it yesterday and it ran like crap :wallbanging:. So i tried swapping and cleaning carbs to no solution. Then I took the spark plug out and watched the spark and about every 5 seconds or so it would ''skip a beat''. Could my condensor be shot? Points? I tried numorous spark plugs but got the same problem, Thanks for any help.
#20 bread320i OFFLINE
bread320i
  • 614 Thanks
  • 1225 posts
Posted March 05, 2011 - 02:23 PM
Have you filed and cleaned the points recently?
#21 Stoneman OFFLINE
Stoneman
    Masseyholic
  • 26 Thanks
  • 157 posts
Posted March 05, 2011 - 04:11 PM
No, i will try that today, Thanks for the help!
#22 Stoneman OFFLINE
Stoneman
    Masseyholic
  • 26 Thanks
  • 157 posts
Posted March 05, 2011 - 06:32 PM
Has any one put electronic ignition on a tecumseh? i have a newer 6hp techumseh with one and was wondering if it might work. Thanks for any help!
