I Found It! I Found It!
scut cut case articulated
23 replies to this topic
#1 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted March 08, 2014 - 12:39 AM
As many of you know, I've been looking for a compact tractor with four wheel drive, diesel power, and power steering.  Another thing I've been interested in but never thought I'd find, is an articulated machine.
Today I was visiting my old job, trying to find a loader from a skid steer that would fit on a front mount mower like a Toro or Kubota, when I stumbled upon this:
Since my former job is a salvage yard for construction equipment... I knew there would be some problems.... For example, the engine is a Wisconsin WH40, and is missing the RH cylinder head and the piston is rusted into the bore... but, I don't want to run gasoline in it anyway.  I could put the Mitsi L3E in it, or even a bigger Kubota if I come across one.
But, the valves all still moved, the steering cylinder is there... I don't care about the chain trencher, as I want a tractor... so I was pretty optimistic until....
I walked around to the other side....
That's when I found this, or rather should say didn't find.... something.... I looked online and there are a couple of pumps that are mounted on the right hand side--I directly to the flywheel, and 1 running from a belt off the flywheel.
So, is anyone familiar with the Case/Davis 30-4 trenchers?  What are the missing pumps used for??? Are they necessary to run this machine as a loader/backhoe? Or, can I substitute something...
Thanks,
Smitth
Edited by Utah Smitty, March 08, 2014 - 02:03 AM.
  • hamman, boyscout862, New.Canadian.DB.Owner and 2 others have said thanks
#2 oldedeeres ONLINE
oldedeeres
  • 9,427 Thanks
  • 4,743 posts
Posted March 08, 2014 - 12:56 AM
I am green with envy!! You're going to have a ball working on it, and then with it. Unfortunately I don't have an answer for your questions, but I'm sure someone else will be able to help. A hoe like that has been on my "bucket list" for quite a while now. Congratulations.
#3 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted March 08, 2014 - 02:02 AM
Thanks.I haven't finished the deal,yet, the co. owner is on vacation this week.  Hopefully he'll let it go cheaply... I've seen them on auction, and they seem to sell--running, for around $4000.
Smitty
  • oldedeeres said thank you
#4 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,769 Thanks
  • 4,261 posts
Posted March 08, 2014 - 03:01 AM
Hello Smitty,
I'm pleased to hear you found your ct!
Edited by jd.rasentrac, March 08, 2014 - 03:02 AM.
  • Utah Smitty said thank you
#5 MH81 OFFLINE
Posted March 08, 2014 - 03:18 AM
Be a good project. Hope you can negotiate a deal with lots of headroom for the repair.
#6 shorty ONLINE
shorty
  • 5,431 Thanks
  • 5,247 posts
Posted March 08, 2014 - 05:36 AM
That looks like an interesting machine. Not knowing a whole lot about them, but seeing them used from time to time. It seems likely that it would have separated hydraulic systems, one for the ditcher and another for the drive. Sounds cool, hope it works out for you.
#7 skyrydr2 OFFLINE
  • 3,886 Thanks
  • 3,410 posts
Posted March 08, 2014 - 05:54 AM
Cool machine for sure ! But expensive to repair if the pumps go bad... As it ruins everything... I see lines off the main pump not a good sign? Make sure all the valves are still there and working.
No stabilizers , but a blade in the rear.. if you want a TLB ( tractor loader backhoe) this rig could work but as tractor for garden stuffs.... Not sure how you could get the hoe and blade off to get a hitch and pto on? Actually pto is the easy part... Make it hydraulic... But getting the other stuff off and on???? That would be the tricky part.
#8 KennyP ONLINE
  • 38,173 Thanks
  • 45,836 posts
Posted March 08, 2014 - 06:39 AM
That's pretty cool, Smitty! Hope you can get it cheap.
Here's  a pic of the pump side:
  • trowel, Utah Smitty, Newpaws493 and 1 other said thanks
#9 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted March 08, 2014 - 07:21 AM
Whoa, that's a Heavy duty unit Smitty.  Looking at the picture above it looks like there are some large lines running back to the rear section drive and Hoe. You'll need to look it over carefully and determine what's missing and come up with some kind of parts estimate. If you can use generic pumps they might not be that pricey but I'm sure the Case parts would be high. If all the lines need replacing that alone could run you big$.
#10 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted March 08, 2014 - 07:28 AM
Manual, you need parts manual and operator's manual for the machine.
Don't know anything about them,
I think it is a good idea, modifying a trencher, heavy duty stuff,  have always wanted to try a all hydro driven tractor,
As the guys said, check everything first, she looks rough.
#11 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted March 08, 2014 - 07:49 AM
I had a 20+4 and a 25+4.I am pretty sure that there was not a pump mounted on the left side.The larger pump on the right side on mine was a Sundstrand which only run the drive motor for travel and the smaller pump mounted on the outside of the Sundstrand ran all other hydraulic functions.
  • Utah Smitty and Oldford have said thanks
#12 Arti OFFLINE
Arti
  • 1,363 Thanks
  • 989 posts
Posted March 08, 2014 - 07:53 AM
That is a Must have toy.
#13 Oldford OFFLINE
Oldford
  • 1,134 Thanks
  • 786 posts
Posted March 08, 2014 - 08:03 AM
Is that a rental sticker, maybe get it for scrap price if was run hard put up wet now in the boneyard.  Someone on here has parts for Wisc. engines..?..  Maybe get it running cheap see everything work then sell wisc engine if you install diesel and not have a fortune in it       just my .02
#14 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted March 08, 2014 - 08:14 AM
It does look like a pump was mounted on the left side but it also looks like the two pumps that my trencher had are mounted on the right side.Maybe an oil filter on the right side?
I bought a 25+4 for parts and it was a later model than the one I was using and there were significant changes made and many of the parts were different than mine so be careful assuming all 30+4 trencher information is the same.
#15 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted March 08, 2014 - 09:05 AM
Smitty, check your parts prices first before you go too far.  If I was you, I would negotiate up from scrap price and see what happens.
I am one of the ones with parts for those Wisconsins.  I also have salvage parts to make 'er cheap.
Ben W.
  • MH81, Utah Smitty and Oldford have said thanks
Also tagged with one or more of these keywords: scut, cut, case, articulated
