Cub Cadet Crank Shaft Issues
11 replies to this topic
#1 cubcadet1987 OFFLINE
cubcadet1987
  • 1 Thanks
  • 3 posts
Posted March 05, 2014 - 06:45 PM
I'm trying too rebuild my cub cadet 102 10hp engine and i need a new crank shaft. Does any one know if i can use a crank shaft out of 12hp kohler in a 10hp block if i get it bored out to 12 or 13hp. I want to know
#2 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted March 05, 2014 - 07:10 PM
I have no idea but, :welcometogttalk:
#3 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted March 05, 2014 - 07:11 PM
What is wrong with your crank?  Maybe it can be fixed.  You can by undersized connecting rods and have the crank polished, if that is the issue.  If it is chipped, you might be able to get it welded & ground.
  • trowel and superaben have said thanks
#4 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted March 05, 2014 - 07:21 PM
:iagree:
Ben W.
#5 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted March 05, 2014 - 08:48 PM
different stroke on crank shaft
  • trowel said thank you
#6 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted March 05, 2014 - 08:53 PM
Welcome to the fourm, those K block Kohlers are good engines.
I second the over size rod, cap and regrind the crank pin, while your there check the piston and rings.
  • Chris11 and New.Canadian.DB.Owner have said thanks
#7 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted March 06, 2014 - 06:09 AM
Have a look in the manuals section under engines-Kohler and you will find an engine rebuilding guide for K series as well as some documents on crankshafts. You may find the info. you need there.
#8 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted March 06, 2014 - 06:16 AM
http://gardentractor...om/engspecs.htm
#9 searstractorfan OFFLINE
searstractorfan
  • 122 Thanks
  • 158 posts
Posted March 06, 2014 - 03:17 PM
I've heard of boring 10s to 12s and swapping cranks and such.. I think I have a good crank for a 10 if needed
#10 cubcadet1987 OFFLINE
cubcadet1987
  • 1 Thanks
  • 3 posts
Posted March 06, 2014 - 06:11 PM
I'm trying too rebuild my cub cadet 102 10hp engine and i need a new crank shaft. Does any one know if i can use a crank shaft out of 12hp kohler in a 10hp block if i get it bored out to 12 or 13hp. I want to know, I broke the fly wheel nut off.
Edited by cubcadet1987, March 06, 2014 - 06:13 PM.
#11 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted March 06, 2014 - 07:37 PM
I see you forgot the flywheel nut being broke off in the original posting.
#12 searstractorfan OFFLINE
searstractorfan
  • 122 Thanks
  • 158 posts
Posted March 07, 2014 - 01:03 PM
12-18 is same stroke.. 10 is smaller.. Bore is smaller in 10 then a 12..
