B112 Variable Speed Drive Belt
8 replies to this topic
#1 petrj6 OFFLINE
petrj6
  • 4,084 Thanks
  • 2,369 posts
Posted March 04, 2014 - 08:54 PM
    Ok, looked it up and got the part # for the new belt.  says I need part# 2164080sm , has anyone here gotten this belt for their tractor.  Is it the rite one, does it work effectively.  I don't want to spend $60 on the wrong belt.
#2 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted March 05, 2014 - 12:33 AM
That should be correct. The question is, is the vari drive in good enough condition to warrant spending the money.
#3 petrj6 OFFLINE
petrj6
  • 4,084 Thanks
  • 2,369 posts
Posted March 05, 2014 - 05:38 AM
    I just got done re-building the entire system.  weld buildup on all the shafts, re-machine, new key way's, replaced pulley's. been at it for about three weeks.
  • MH81 and Talntedmrgreen have said thanks
#4 Talntedmrgreen OFFLINE
  • 3,289 Thanks
  • 2,315 posts
Posted March 05, 2014 - 07:22 AM
Worth a shot then, I'd say.  I'd have love to seen a pictorial on the variable before, during and after the fixes...as well as rearl world results in variable speed.
#5 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted March 05, 2014 - 10:52 AM
Agreed, go for it.
#6 Killer_A-C OFFLINE
Killer_A-C
  • 373 Thanks
  • 542 posts
Posted March 05, 2014 - 07:10 PM
I have rebuilt them before.Gather up low wear parts and lube up good.When everything is tight and adjusted to spec they are smooth as silk and can just about do a wheel stand.If you have worn parts you might as well forget it...
#7 petrj6 OFFLINE
petrj6
  • 4,084 Thanks
  • 2,369 posts
Posted March 05, 2014 - 08:15 PM
     OH WHY OH WHY DO HAVE TO TAKE EVERYTHING APPART!!!!!!!!!!!!!!!!!!!!!!   this whole thing started as a whine in the rear while snow blowing, one thing leads to another take the variable speed rear end out due to the spacers chewing into the side cover. put in a standard rear end, modify the input shaft to accept the variable speed drive,  had to re-build all the shafts re-make all the hubs and so on.  finally getting it back together and cant remember where half the bolts go, I am getting it but it's like WHY OH WHY didn't I take pics!!!!!!!!
#8 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 05, 2014 - 08:31 PM
Better to be able to rebuild it before it breaks something, your in good hands here, the guys will help you though.
#9 steve b OFFLINE
steve b
  • 122 Thanks
  • 222 posts
Posted March 06, 2014 - 08:37 AM
The belt is pricey, but after installing a new one and going through the entire adjustment procedure it is working smooth as silk now. I really like the feature for snow blowing. Just move the lever for more or less feed speed, no shifting, can't beat it.
Steve
