First Post About My Jacobsen Chief
19 replies to this topic
#16 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted March 05, 2014 - 02:48 PM
Welcome Dustin
Congrats on your new Chief!!!
Mike
Genoa,IL
66 Chief 1000, 36 snow auger,42 rotary deck
#17 dff110 OFFLINE
dff110
  • 12 Thanks
  • 8 posts
Posted March 05, 2014 - 04:32 PM
Thanks everyone!  I was just going to use it for plowing snow, and fix it up during the winter, but a guy from work has a 42" deck for it.  I think I'm going to pass on the other 2 1200's.  Guy was only asking $400 for everything, but I don't need another collection.
Someday I'll put up some more chainsaw pictures.  Once work slows down I need to get back working in the garage.  I have 6 saws in various stages of Dissasembly, and Reassembly.
I do have a few questions about the Chief.  To me it doesn't seem to have a full throttle (run at top speed).  I'm guessing it could be a carb adjustment problem, or someone has put a aftermarket throttle lever on which could not be set right.  I already have a carb kit for it, should I rebuild the carb even though it runs smooth?
The brake needs to be adjusted tighter, which I think I know how to do.  Also, the drive belt going to the gearbox seems to slip more often before the tires even try to spin.  This seems odd to me, is there a tension adjustment, or is it just the case of a worn belt?
Thanks
Dustin
P.S.
Looking for volunteers to hold onto the buisness end of this.
#18 MH81 OFFLINE
Posted March 05, 2014 - 05:17 PM
These engines don't run at high RPM's like any of the newer stuff. Just be sure not to ore rev it.
The rest, that's for a jake or Ford guy. Good luck. Oh, and if you do decide to pass on the package, you might be asked for directions to the guys house. :D
#19 DAVESTOYS OFFLINE
DAVESTOYS
  • 12 Thanks
  • 23 posts
Posted March 14, 2014 - 01:11 PM
Hi Dustin, I have a 1969 Jac   chief 1000 53077 5332 w/ 1969-Kohler K-241 10HP-Gear drive.
   According to my info 53077 5130 is the same, 1969 Chief 1000 Gear drive.
#20 KennyP ONLINE
  • 40,080 Thanks
  • 46,745 posts
Posted March 15, 2014 - 06:21 AM
If the belt is slipping and looks worn, then it probably needs replaced. It may have stretched some.
