Wheel Weights
6 replies to this topic
#1 superiorpower OFFLINE
superiorpower
  • 41 Thanks
  • 67 posts
Posted March 04, 2014 - 01:41 AM
Hey guys (and gals), I am wanting to add wheel weights but can't afford the real cast iron wheel weights. Anyone have any ideas of makeshift wheel weights? I would be willing to design an extension to bolt to the hub. Primarily this would be going onto a Sears 10/6. I considered using some old car brake rotors but I don't think they have enough weight. I am trying to keep the back end of my machine open so I can use attachments. Any ideas?
  • BTS said thank you
#2 KC9KAS ONLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted March 04, 2014 - 05:07 AM
Welcome to GTT.
If you go to the search box and type "wheel weights" you will find many threads on home-made wheel weights.
  • trowel, boyscout862 and BTS have said thanks
#3 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted March 04, 2014 - 06:28 AM
Heres what I made and use on GT's and on my compact tractor. The cast iron weight lifting plates are getting hard to find here at a reasonable price. http://gardentractor...eight brackets
#4 BTS ONLINE
BTS
    Make Stuff Up
  • 4,260 Thanks
  • 2,459 posts
Posted March 04, 2014 - 08:38 AM
You could also look into fluid filling the tires, there was a thread on here about using rv antifreeze, I was always going to try it but I have never had the time or need for it yet.
Also maybe look around for front wheel weights for a bigger antique tractor, I have some front weights off of a Minneapolis Moline, they weigh around 90lbs each and they fit right into a 12" rim.
Good luck
  • JDBrian said thank you
#5 KC9KAS ONLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted March 04, 2014 - 05:58 PM
I have windshield washer fluid in my tires, and it works well!
#6 superiorpower OFFLINE
superiorpower
  • 41 Thanks
  • 67 posts
Posted March 05, 2014 - 03:23 PM
I did some searching on Google and found some great ideas! Thanks!
#7 mgrubb47122 OFFLINE
mgrubb47122
  • 11 Thanks
  • 7 posts
Posted April 29, 2014 - 06:08 AM
Here is my solution.  They are adapters for the rear wheels that allow you to mount barbell weights.  Been making them for  about 3 years now.  Mike G.
