Suburban 725 Mechanical Help
23 replies to this topic
#16 texagg OFFLINE
texagg
  • 3 Thanks
  • 17 posts
Posted October 07, 2014 - 04:38 PM
Ok. Can someone suggest where to get a replacement motor?
#17 MNGB OFFLINE
MNGB
  • 1,573 Thanks
  • 1,133 posts
Posted October 08, 2014 - 10:59 PM
Hi texagg, here's a  video explaining B&S gov adjusting
GB in MN
Edited by MNGB, October 08, 2014 - 11:00 PM.
#18 texagg OFFLINE
texagg
  • 3 Thanks
  • 17 posts
Posted October 10, 2014 - 11:49 AM
Thanks MNGB. I will give that a shot. I'll let you know how it works out
#19 Texas Deere and Horse OFFLINE
  • 14,594 Thanks
  • 15,426 posts
Posted October 15, 2014 - 10:22 AM
If you get over to Flatonia, I can take a look at it for you and see if we can get it working properly. I forgot all about you over there. Let me know if I can help you out.
#20 texagg OFFLINE
texagg
  • 3 Thanks
  • 17 posts
Posted January 03, 2015 - 08:39 AM
Replaced governor, tried adjusting according to the above post.....still no luck.
Could it be the crankshaft is messed up?
Help!!!
Deere and horse--make Flatonia regularly. May drag it over there with me and let you take a look.
#21 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,569 Thanks
  • 1,298 posts
Posted January 13, 2015 - 08:34 PM
texagg,did you by chance change or have the carburetor changed right before this started ? Also have you tried resetting the govenor linkage ? It may have slipped on the govenor shaft.
Edited by rustyoldjunk, January 13, 2015 - 08:36 PM.
#22 Texas Deere and Horse OFFLINE
  • 14,594 Thanks
  • 15,426 posts
Posted January 13, 2015 - 09:41 PM
Help!!!
Send me PM and I'll give you my phone number, maybe we can get it worked out.
  • rustyoldjunk said thank you
#23 rustyoldjunk OFFLINE
rustyoldjunk
  • 2,569 Thanks
  • 1,298 posts
Posted January 13, 2015 - 09:56 PM
Not all carbs have the ear in the right position on the throttle shaft,some are opposite. If you use a carb with a backwards ear on the throttle butterfly shaft the govenor will work backwards and all out of wack. I have had to change the position of the ear on the throttle shaft on two or three carbs over the years.
  • Texas Deere and Horse and Lauber1 have said thanks
#24 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,475 Thanks
  • 2,811 posts
Posted January 13, 2015 - 11:04 PM
there are some different set ups on the Suburbans. On the older air vanes it was easy to get the linkage flipped the wrong way over center. this causes the engine to only have full throttle. Might be something like that has happened here. Hard to lay a finger on this problem with out some history on the motor and what's been done to it.
