Lennox Kittytrack 600
14 replies to this topic
#1 fireman OFFLINE
fireman
  • 12 Thanks
  • 28 posts
Posted March 03, 2014 - 10:12 AM
Hey All,
I picked this up almost 2 years ago and have had it tucked away waiting for time to restore it. I have been gathering information on it ever since and now have the original manual, brochures, price lists etc. I have also been in contact with Jerome who restored his and have gotten some great tips and info that will help me with mine. I already have a local metal house set to manufacture new track pads. I also have a list of new parts including bearings, belts and drive chain that I need to order. It's on the lift and I have started to dis-assemble it. I know I have some metal in the bottom of the body that will need to be cut out and replaced once I get it sandblasted. Like Jerome I plan on running rubber on the track pads. My goal is to have this done for the Fall Festival in September at the Connecticut Antique Machinery Association Museum in Kent, CT. We'll see what happens.
Edited by fireman, March 03, 2014 - 06:34 PM.
  • hamman, Username, boyscout862 and 2 others have said thanks
#2 DougT OFFLINE
DougT
    Dog Approved
  • 6,926 Thanks
  • 4,994 posts
Posted March 03, 2014 - 10:48 AM
That's a nice looking Kitty. Almost too good to restore, in my opinion. They're only original once!!
#3 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,951 Thanks
  • 1,865 posts
Posted March 03, 2014 - 11:51 AM
I agree with DougT.
If that is the original paint and decals, it is in way to good a condition to "restore".
They are extreamly hard to find in that original condition.
However, if that is a re-paint, than by all means go ahead and restore it.
Edited by jdcrawler, March 03, 2014 - 11:53 AM.
#4 lyall ONLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted March 03, 2014 - 12:43 PM
it looks like somebody restored it years ago - all but the tracks
to see an original you have to come to Marshalltown Ia
Lennox has one in there show room
#5 boyscout862 ONLINE
  • 12,849 Thanks
  • 9,170 posts
Posted March 03, 2014 - 12:47 PM
I hope to see you and it there. Good Luck, Rick
#6 fireman OFFLINE
fireman
  • 12 Thanks
  • 28 posts
Posted March 03, 2014 - 01:50 PM
It actually looks a lot better in the pictures then in real life. I wouldn't say this has been restored before but someone did repaint it at some time. I'm under the same rule that it's only original once but this one is far from a survivor. Every bearing is shot! The tracks and drive chains have had it. I had it running (barely) when I first got it. Not sure of the condition of the engine but I will rebuild the carb, do a compression test and see where it goes from there. There is a bunch of metal that will need to be cut out and replaced. Both foot areas and areas in the bottom below the seat need replacement. Hopefully it will look as good as Jerome's came out. I'm more of a mechanical, machining, and welding guy instead of a body guy but I should be able to handle it. The same metal house that is going to make the new tracks also does powder coating some I going to have them do pretty much all the parts that are yellow. The rest I will paint myself.
Here are a few pictures showing the "BAD" metal. Looks like someone patched a hole in the hood also. Looks great on the top but no grinding or finishing underneath.
  • DougT and superspeedex have said thanks
#7 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted March 03, 2014 - 04:29 PM
looking forward to seeing the finished product!! im doing a struck md 55 now
#8 glgrumpy ONLINE
  • 8,609 Thanks
  • 7,920 posts
Posted March 03, 2014 - 06:21 PM
yep, looks like a paint-over for sure. Think part of problem is NO holes for waters and dirt to fall out of and just collects and rusts.  Wonder if you could put some in or expanded metal where your feet go or ?? to keep from happening again. The battery box also needs one of those special absorber pads to keep acid damage away. Maybe a hole or two in it? If you make small holes, then bend down the edges, say with a ball or curved item in a press, it will look like stamped that way.
#9 fireman OFFLINE
fireman
  • 12 Thanks
  • 28 posts
Posted March 03, 2014 - 06:41 PM
Once this dozer is restored it will never see a drop of water or bad weather . It will purely be for show. I keep all my tractors in my heated workshop. I will put a battery tray and pad under the battery.
#10 powerstroker00 OFFLINE
powerstroker00
  • 669 Thanks
  • 332 posts
Posted March 03, 2014 - 07:52 PM
looks like a good project. does this one have starter/gen? we have one with and one without. think maybe the pull start is older, don't know for sure though.
#11 wilberj ONLINE
wilberj
  • 5,003 Thanks
  • 5,595 posts
Posted March 03, 2014 - 08:30 PM
Good to talk to you over the phone cant wait to see her all done.
#12 wilberj ONLINE
wilberj
  • 5,003 Thanks
  • 5,595 posts
Lennox built both each year a pull start and one with a starter.
His is a newer one by the hood and holes in the drive area.
  • powerstroker00 and superspeedex have said thanks
#13 fireman OFFLINE
fireman
  • 12 Thanks
  • 28 posts
Posted March 03, 2014 - 09:02 PM
This does have the electric start. There were 2 models offered. The electric start was the KTEI-600-2 and cost $540. The pull start was the KTI-600-2 and cost $450. This was for the 1964-65 year.
  • bulm said thank you
#14 ronstoys OFFLINE
ronstoys
  • 1 posts
Posted November 02, 2014 - 07:50 PM
I recently aquired a kitty track with electric start however the engine is missing the shroud piece that has the id numbers. making it impossible to look for the carb linkages that are missing.  perhaps some one could supply me with the model  numbers from one with orginal engine, that i could use to search. thanks Ron
#15 wilberj ONLINE
wilberj
  • 5,003 Thanks
  • 5,595 posts
Posted November 02, 2014 - 10:08 PM
Hi Ron send me a Pm so I dont forget and I'll take look at mine for you.
  • ronstoys said thank you
