What To Get My Head Milled On My K241
9 replies to this topic
#1 searspullingtractor OFFLINE
searspullingtractor
  • 34 Thanks
  • 103 posts
Posted March 02, 2014 - 10:18 PM
will .50 make the valves hit the head
#2 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted March 02, 2014 - 11:37 PM
See what a machine shop can do for you.
#3 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted March 03, 2014 - 04:04 AM
Do you mean .050? That's a lot for a stock head ! It will be a lot weaker and could fail.
#4 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted March 03, 2014 - 07:20 AM
Taking .050 you may have to check valve clearance. It may just start tapping the valves. take it down .035 and you can put some playdo on the valves bolt the old gasket on and check thickness. I run mine wide open under a load and and the little stock spring just don't have the spring you need to keep them from floating.
Edited by Chris11, March 03, 2014 - 07:22 AM.
#5 searspullingtractor OFFLINE
searspullingtractor
  • 34 Thanks
  • 103 posts
Posted March 03, 2014 - 09:14 AM
would .030 so anything
#6 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted March 03, 2014 - 10:29 AM
Your not going to feel anything diffrant. I mean everything you can do to improve the way the engine was built. By valves springs carb. the stuff that make it run better. Valve angle job ports size. If you really just want to some things Find a # 30 carb for it . that will change a lot. Take off .030  clean your valves up. The k engine you cant change any timing with out putting a cam in. Timing is big also
#7 searspullingtractor OFFLINE
searspullingtractor
  • 34 Thanks
  • 103 posts
Posted March 03, 2014 - 10:33 AM
will the valves hit at .030 and thanks looking for a cam to
#8 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted March 03, 2014 - 10:54 AM
I don't think so, but after you may want to test with playdo
#9 Rbrracing32 OFFLINE
Rbrracing32
  • 16 Thanks
  • 56 posts
Posted March 03, 2014 - 12:13 PM
With a .330 cam. I cut my head where all tbe gasket surface was so it was flat where the piston area is on the head do it with a mill or you want get it flat. and no hittng using the stock thick head gasket.
#10 oaktown1987 OFFLINE
oaktown1987
  • 11 Thanks
  • 34 posts
Posted March 17, 2014 - 11:06 PM
Brian millers garden tractor tells u what the limit is
