Kohler K161 Connecting Rod ?
8 replies to this topic
#1 IamSherwood OFFLINE
  • 8,391 Thanks
Posted March 02, 2014 - 06:52 PM
Today I pulled the pan off a K161, to replace the leaking
gasket. In the pan I found a small strip if metal. (1 3/8" x 3/16" x .050")
Upon inspection, I discovered it is part of the tabbed
rectangular lock washer for the connecting rod bolts.
I can't seem to find it listed anywhere.
Is that tab washer still available, or obsolete?
Should I just use lock washers, and/or Loctite?
Thanks.
#2 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted March 02, 2014 - 07:32 PM
Hi again Will. :wave:
http://www.ebay.com/...=item1c3c1d4160
I saw that most of the master rebuild kits only show a lock washer? But then again it was kind of hard to tell in the pics.
  • Alc and IamSherwood have said thanks
#3 IamSherwood OFFLINE
  • 8,391 Thanks
Posted March 02, 2014 - 07:59 PM
Thanks again Chris :wave:
I had just found that on ebay too.
I don't want to wait  2 weeks for the mailman, and spend $15, so
I think I'll just go with lock washers.
  • chris m said thank you
#4 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted March 02, 2014 - 09:09 PM
In my opinion, I would opt to go with that style lock on an original rod.  That lock is what you bend up to hold the bolts from turning.  Don't risk it in my book.  Lock washers and lock tight are not infallible.  They will come loose.  The tab will hold the bolt still until the thing blows up or rots.
What you need is a 230525, like Chris showed.  Yes it is obsolete of course.  Kohler has a different lock design on their rods now.  I might be able to get you one.
Ben W.
  • Gtractor, IamSherwood, trowel and 1 other said thanks
#5 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted March 02, 2014 - 09:14 PM
    Not sure about kohler but the briggs I rebuild I have had the same trouble, lock plate lost or destroyed, in the past I have just cut a piece of guage metal bent it to fit and drilled two holes in it.  Put it In where it belongs and torque the bolts down, then bend the corners up, viola done.  not the greatest but it has worked for me in the past.
  • Gtractor, Alc, IamSherwood and 3 others have said thanks
#6 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted March 02, 2014 - 09:22 PM
Ben W.
:ditto:
:ditto:
  • superaben said thank you
#7 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted March 02, 2014 - 09:28 PM
I was going to suggest the same idea.
  • IamSherwood and superaben have said thanks
#8 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted March 02, 2014 - 09:29 PM
Yep, been there done that, too.  :thumbs:  Glad you said something.
Ben W.
  • IamSherwood and boyscout862 have said thanks
#9 IamSherwood OFFLINE
  • 8,391 Thanks
Posted March 04, 2014 - 07:56 AM
Ben W.
Thanks guys. That's what I'm going to do.
What I found.
  • trowel said thank you
