2 More Tractors...
20 replies to this topic
#16 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,101 Thanks
  • 4,879 posts
Posted March 05, 2014 - 07:37 PM
Jim, If ya paint that 140 red it'll start right up!  :smilewink:  :wave:
Both great finds!
  • jimbobbillyray said thank you
#17 jpackard56 OFFLINE
jpackard56
  • 1,837 Thanks
  • 1,434 posts
Posted March 05, 2014 - 08:42 PM
For that kinda $ for a 140 I think I could put up with the wrong green for a while, but side by side it is kinda  yuggly, ya might want to cover it with a couple cans yourself until you can do it proper so as to not upset the other units on the team :thumbs:
#18 Sawdust OFFLINE
Sawdust
  • 5,562 Thanks
  • 3,335 posts
Posted March 05, 2014 - 09:28 PM
Nice haul, glad you got it back. I like the Ag's.
#19 jimbobbillyray ONLINE
jimbobbillyray
  • 2,788 Thanks
  • 2,755 posts
Posted March 05, 2014 - 10:15 PM
     :bigrofl: not gonna happen.....
Edited by James henry, March 05, 2014 - 10:19 PM.
  • Trav1s said thank you
#20 grnspot110 ONLINE
grnspot110
  • 4,096 Thanks
  • 2,619 posts
Posted March 06, 2014 - 07:32 AM
Both great finds!
You could be right, but only if it's the right shade of red!  John Deere did paint some tractors "construction" red!  ~~  Lowell
  • Gtractor, jimbobbillyray and Trav1s have said thanks
#21 jimbobbillyray ONLINE
jimbobbillyray
  • 2,788 Thanks
  • 2,755 posts
Posted March 06, 2014 - 06:53 PM
Played around with the 140 today after work.  I tried to start it, but it would only turn over.  I had a feeling it was a stuck float on the carberator problem.  The gas in the tank smelled pretty old.  I took off the hose from the tank to the carb and let the old gas run out, then put it back on and put fresh gas in the tank.  I backed out the air and gas needles on the carb, cleaned them, and  put them back and set them to 1 1/2 turns out.  I tapped on the carb a few more times (I have seen a stuck float before), then backed off the nut on bottom of bowl.  Nothing happened.   I tapped on the carb a few more times, and then some gas started running out of the bowl. so I know I had freed up the float. I let plenty of gas run thru the carb bowl ( I never took off the bowl, I just took off the nut on the bottom....no telling if the bowl gasket was any good or not so I did not want to break it loose).   Then I screwed the nut back on the bottom of the carb bowl. Then I gave it gas and choke and turned the key.  The old girl fired up!  No smoke, and it runs great too!  That's the good part.  Then I learned the hydro traanny is not working.  The tractor will go backward fine, but will just barely go foward.  The mower deck goes up and down fine tho.  I am hoping the problem is only one of the relief valves....I have a 140 parts tractor with a good tranny if this one is no good.  But, at least now the motor runs !
  • twostep said thank you
