New Truck
19 replies to this topic
#1 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted March 01, 2014 - 08:02 PM
Spend months finding this year and model. I wanted a 94. It's the first year of the electrical injection pump. It'll run on waste oil, kero, and just about anything else. I personally won't run anything higher than a 50/50 mix.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
  • hamman, boyscout862, New.Canadian.DB.Owner and 3 others have said thanks
#2 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted March 01, 2014 - 08:04 PM
It's fully loaded and everything works. I'll be doing a lot to it. First thing was to pull the visor and ground effects
  • hamman and sacsr have said thanks
#3 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted March 01, 2014 - 08:06 PM
Rust ate the bed and fenders. Repop parts are cheap but I like oem. I bought a parts truck.
The parts truck has 3.73s. I'm thinking about ditching the 4.10s in the dually.
  • hamman said thank you
#4 TAHOE OFFLINE
TAHOE
  • 8,171 Thanks
  • 5,760 posts
Posted March 01, 2014 - 08:19 PM
Nice!!!
I kind of like the sun visors, if not do love the roof lights, always wanted to put them on the Tahoe.
Man, wished I could find a parts truck for my dad's truck, I need so many parts.
What year is the parts truck?
#5 farmerall OFFLINE
farmerall
  • 2,207 Thanks
  • 1,475 posts
Posted March 01, 2014 - 08:26 PM
Nice truck, too bad the rust got to it so bad. The parts truck looks like it has a nice body on it though.
#6 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted March 01, 2014 - 08:54 PM
The parts truck is a 96. It's got a few dents but that's so much easier to repair than rust.
#7 TAHOE OFFLINE
TAHOE
  • 8,171 Thanks
  • 5,760 posts
Posted March 01, 2014 - 09:19 PM
I was hoping it was a 93, need a 4x4 tranny for dad's
The parts truck looks to be in pretty good shape, cab is decent.
#8 farmerall OFFLINE
farmerall
  • 2,207 Thanks
  • 1,475 posts
Posted March 01, 2014 - 10:16 PM
Is it an auto or standard. If it's a auto it's most likely a 700r4 which shouldn't be hard to find one used. I know chevy/ gmc trucks were using them in 88. Also a tranny from a 4x4 S10 of roughly the same age will work for you too, I know the trans from the square body S10 will work. I'm not sure about the newer body style. The only difference between the S10 trans and a fullsize trans are minor outside things and the torque converter. It will bolt up and work fine, you just need to use the torque converter from the fullsize truck.
  • TAHOE said thank you
#9 toomanytoys84 OFFLINE
toomanytoys84
    Aaron
  • 10,496 Thanks
  • 6,180 posts
Posted March 01, 2014 - 11:26 PM
id like to find a truck around that year. Short box reg cab 4x4
#10 TAHOE OFFLINE
TAHOE
  • 8,171 Thanks
  • 5,760 posts
Posted March 02, 2014 - 09:07 AM
It's actually a 4L60E, 93 was first year to go full electronic. 93-94 will direct swap, 95 was a year all it's own as GM was prepping to switch to OBDII, it has it's year only shift solenoids, then 96 and up will swap. People may believe S10 trannies are the same, but they are light duty. I know plenty of people who have done V8 swap in S10's/Astros and tranny lasted short time. V8's need 6 shifting plates -vs- 5 in S10 trannies to make a druable tranny behind torque/HP.
I could pull it and my BIL will do rebuild for about $300-350. but truck is ate up with cancer and needs other stuff beside just tranny. I hate to do it, but maybe a parts truck at this point. I may pull motor, sell the rest.
#11 UncleWillie OFFLINE
  • 16,105 Thanks
  • 8,906 posts
Posted March 02, 2014 - 06:53 PM
Nice truck. On the diesels they had problems with the intake manifold gaskets. You might want to look into it.
Actually Tahoe some 94s (like mine) have the 95 year model 4l80e in them. The 94 was the best year for the GMT400. After that the gassers went to the Vortec system that didn't have the low end torque of the TBI models.
#12 DougT OFFLINE
DougT
    Dog Approved
  • 7,077 Thanks
  • 5,061 posts
Posted March 02, 2014 - 11:31 PM
The 4L80E was introed in 91. You just need over 8600 GVW to get it.
#13 UncleWillie OFFLINE
  • 16,105 Thanks
  • 8,906 posts
Posted March 02, 2014 - 11:55 PM
Yes, but not in the suburban
#14 DougT OFFLINE
DougT
    Dog Approved
  • 7,077 Thanks
  • 5,061 posts
Posted March 03, 2014 - 08:10 AM
I don't buy that one, Willie. A quick check of the GM parts catalog for a 93 Sub shows the 4L80 as an option. I don't recall them ever using the 4L60 in anything with 8 lug hubs.
#15 UncleWillie OFFLINE
  • 16,105 Thanks
  • 8,906 posts
Posted March 03, 2014 - 11:09 AM
HUmmm. When We were working on the Burb we had a hard time finding a wiring diagram. The GM dealership told us that the 4l80e in my truck didn't come out till 95. Maybe it is just something particular about my transmission.
