Squire 9 Bevel Gearbox Bearings Change.
8 replies to this topic
#1 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted February 27, 2014 - 07:44 AM
Looking at the manual and over the net regarding changing the main input (drive shaft) needle and ball bearing it seems the output shaft gear (side) has to be pulled out of the way first before removal of the input gear and shaft.
Just in case the gears are worn badly is there anyone out there with good BGB gears they might be willing to sell if needed ?
#2 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted February 27, 2014 - 07:48 AM
This might help.
http://gardentractor...-bevel-gearbox/
  • MH81, trowel and boyscout862 have said thanks
#3 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted February 27, 2014 - 07:52 AM
One stop answer, has to be the fastest in GTTalk history, you got it :thumbs: many thanks and then some.
Edited by trowel, February 27, 2014 - 07:53 AM.
#4 boyscout862 OFFLINE
  • 13,689 Thanks
  • 9,474 posts
Posted February 27, 2014 - 09:56 AM
Boston Gear used to be able to supply most gear sizes. I've still got a 25 year old catalog but don't know if they are in business anymore. There is the sponsors here and if necessary the sponsors at www.simpletractors.com . Sandy Lake has been mentioned many times for parts.
Was Kahn Tractor able to help with your Ford? Good Luck, Rick
I found them http://www.bostongear.com/
Edited by boyscout862, February 27, 2014 - 10:00 AM.
  • trowel said thank you
#5 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted February 27, 2014 - 10:35 AM
Yes, many thanks, they had the gaskets and will be here soon.
Will update the progresses on the 1200.
Thanks again.
#6 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted February 27, 2014 - 11:40 AM
The is an ad for a "mid PTO" on the Hamilton Kijiji site.  Same fellow have 3 sets of BGB gears, but I don't see that ad currently.
http://hamilton.kiji...QAdIdZ546678618
#7 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted February 27, 2014 - 09:44 PM
Many thanks, i will call him if needed.
#8 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 01, 2014 - 06:13 PM
After cleaning out the fuel tank i had some time so broke down the tractor.
  • boyscout862, New.Canadian.DB.Owner and Gabriel have said thanks
#9 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 01, 2014 - 06:52 PM
In very good shape inside with a few spots of rust but hit it with engine degreaser and a thorough rinsing with Joy it is drying now.
With ethanol in gas the little spots of rust will grow very quickly so lining the tank after completely dry.
  • Gabriel said thank you
