Wisconsin Abn Mystery Screws
24 replies to this topic
#16 Alc ONLINE
  • 6,910 Thanks
  • 7,472 posts
Posted March 02, 2014 - 05:58 PM
Went to see what the motor looked like that was above the garage but struck out again , sorry
  • Traill95 and New.Canadian.DB.Owner have said thanks
#17 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted March 02, 2014 - 06:10 PM
Thanks for trying.  That's all a fellow can ask.  Unfortunately, my governor / throttle set up wasn't in the manual Trowel sent me either.  Starting to think this is some one-of jury-rigged setup Waterloo dreamed up to solve the backward facing engine problem created by needing the output pulley on the left side.
  • Traill95 said thank you
#18 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted March 02, 2014 - 06:15 PM
PM'ed you a PDF manual for all the different gov. linkages.
Buried deep in my files.
But the hunt's afoot,....
#19 drbish ONLINE
drbish
    Collecter
  • 1,557 Thanks
  • 1,361 posts
Posted March 02, 2014 - 06:46 PM
Here is a picture of the other side,this is the wards ,i had, do not remember for sure but i think the chain hook up to the parts under the muffler on the picture
Edited by new restorer, March 02, 2014 - 06:48 PM.
  • Alc, Traill95 and New.Canadian.DB.Owner have said thanks
#20 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted March 02, 2014 - 07:04 PM
 9 time out of 10 they all use the same set up, the Wards Plow Trac below shows the set up for more ideas.
#21 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted March 02, 2014 - 07:16 PM
Here's part of it from another view :
#22 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted March 02, 2014 - 07:22 PM
Hope springs eternal!  There is definitely a spring, and it looks like it attaches to the hole in the throttle rod, not the governor lever.  I have a piece of wire in that hole to keep the rod from popping out of the lever.
  • trowel and Traill95 have said thanks
#23 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted March 02, 2014 - 07:27 PM
Your welcome.
#24 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted March 08, 2014 - 02:03 PM
Well, we finally got some above freezing temperatures on a day that I don't have to work.  I got out to the garage & sorted through the can of spare hardware.  Here is what I came up with.  The spring was the hardest part.  I don't have the original and the hole in the governor rod is about 0.020".  That limits the stiffness of the spring, and thus the top speed of the engine.  Works okay, but I am going to keep looking for a stiffer spring.
Thanks again for all your help!
  • Alc and Traill95 have said thanks
#25 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted March 08, 2014 - 06:54 PM
Sweet :thumbs: original and everything, now you have the right throttle control set up.
