Wisconsin Abn Mystery Screws
24 replies to this topic
  • 2,325 Thanks
  • 1,496 posts
Posted February 26, 2014 - 02:05 PM
My Wisconsin ABN has two screws on the carb side of the shroud.  There appears to be / have been spacers under the screws. They are factory.  The primer covers the nuts welded to the inside of the shroud.  Any idea what they are for?
#2 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted February 26, 2014 - 04:07 PM
If i remember correctly, for throttle set up, i think the spacer was for the lever.
Will pull out the manuals and look.
  • New.Canadian.DB.Owner, WNYTractorTinkerer and superaben have said thanks
#3 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,476 Thanks
  • 2,811 posts
Posted February 26, 2014 - 07:47 PM
I agree, wissys were the kings of putting a handle some place on the engine for speed control. A lot of times they were a simple thing with a bunch of little notchs in a full moon shape. Most of mine bolt to the block somewhere. They also used a lock cable thing, where you pulled it out and turned it a quarter turn to set it.
  • trowel said thank you
#4 New.Canadian.DB.Owner OFFLINE
  • 2,325 Thanks
  • 1,496 posts
Posted March 01, 2014 - 10:24 AM
jtrojek has found a picture that would confirm that they are for the throttle.  I can even see the scars from the cable on the shroud, now that I know what to look for.  Does anyone have a photo that would show the pivot mechanism and the connection to the governor or carb?
#5 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,476 Thanks
  • 2,811 posts
Posted March 01, 2014 - 11:34 AM
some of the wissy engines just had a spring on the end of the throttle wire, that hooked up to the govern linkage
#6 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted March 02, 2014 - 07:09 AM
Ah, nice find ! I have the much later one for the teledyne engines, still looking.
#7 New.Canadian.DB.Owner OFFLINE
  • 2,325 Thanks
  • 1,496 posts
Posted March 02, 2014 - 02:29 PM
Well, I'm half way there.  Back in 2011, rscurtis posted a photo on MTF of an ABN he found.  It shows the the pivot and what appears to be a chain going under the carb to ... who knows where.  Now I just need to see the other side.
#8 Alc ONLINE
  • 6,606 Thanks
  • 7,332 posts
Posted March 02, 2014 - 03:06 PM
Would that be the same engine as on my Tri-trac ?
#9 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted March 02, 2014 - 03:14 PM
I usually see a wire, not a chain, but would not be shocked if it was correct, it hooks to the hole in the gov. lever.
Just need to find the throttle lever correct for yours now.
Edited by trowel, March 02, 2014 - 03:15 PM.
#10 New.Canadian.DB.Owner OFFLINE
  • 2,325 Thanks
  • 1,496 posts
Posted March 02, 2014 - 03:29 PM
I am not sure what engine is in a Tri-trac but it could very well be the same engine.
The is only one hole in the governor lever, and the throttle rod for the carb sits in it, just like in rscurtis' second photo. Is there another hole I'm missing or not seeing? Should there be a spring on the end of the chain?
#11 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted March 02, 2014 - 04:18 PM
Huh, no hole ? going by memory which is there, but shady, a spring would make sense.
No help to you but on the AEN there is a spring with twist type throttle.
#12 Alc ONLINE
  • 6,606 Thanks
  • 7,332 posts
Posted March 02, 2014 - 04:27 PM
Here's some pic's of the Tri-Trac I do have another motor above the garage that came from a grain elevator  ,so I was told if these aren't good enough
  • trowel and New.Canadian.DB.Owner have said thanks
#13 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted March 02, 2014 - 04:38 PM
ALC,
Looks like you have the Winnie AKND with the Zenith carb.
  • Alc and New.Canadian.DB.Owner have said thanks
#14 New.Canadian.DB.Owner OFFLINE
  • 2,325 Thanks
  • 1,496 posts
Posted March 02, 2014 - 04:56 PM
Thanks for the photos, Alc, but your throttle setup is different than mine.
Assuming the muffler is forward,  your throttle comes in from the back right corner.  Mine comes in on what would then be the front left corner.   The cable connects to a pivot lever on the flywheel shroud and then a chain or wire goes under the carb.  That's the mechanism I am hoping to see.
Edited by New.Canadian.DB.Owner, March 02, 2014 - 04:58 PM.
#15 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted March 02, 2014 - 05:37 PM
PM'ed you a PDF manual for all the different gov. linkages.
Buried deep in my files.
