Ford 100 Not Charging
7 replies to this topic
#1 GreggHarris OFFLINE
GreggHarris
  • 5 Thanks
  • 5 posts
Posted February 25, 2014 - 08:52 AM
I am having some charging issues with my tractor.  I read a post by Old Blue 120 (page 3, Battery going dead while using tractor) he was helping someone out who was having charging issues but I am not sure I understood the trouble shooting procedures.  The first place I would like to start is with the starter/generator -  there are two  terminals one smaller one on top and towards front of S/G and a larger one towards the rear of the S/G.  With the tractor running I tested these two terminals -  the smaller one towards the front of tractor basically tested nothing but would flip up 1 or so and then 0 again however the bigger terminal towards rear of S/G would test 12+ volts.  With this in mind are my issues with the starter/generator or they farther down the trail of charging system?
#2 HDWildBill OFFLINE
  • 8,985 Thanks
Posted February 25, 2014 - 10:09 AM
Are you sure you have a starter generator?  I'm not familiar with the Ford 100 so I checked the repair manual and it indicates you should have an alternator.   If you do not have a manual or schmatic to go by you can download it from our manuals section.  This is the manual I was looking at.  Hope this helps.
#3 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,449 Thanks
  • 1,869 posts
Posted February 25, 2014 - 10:13 AM
If the engine is original then there should be a S/G
  • HDWildBill said thank you
#4 tinbender7 OFFLINE
tinbender7
  • 1,115 Thanks
  • 784 posts
Posted February 25, 2014 - 10:17 AM
my Ford 100 has a S/G
#5 GreggHarris OFFLINE
GreggHarris
  • 5 Thanks
  • 5 posts
Posted February 25, 2014 - 10:19 AM
The tractor model # is 53059 - 4240, and engine is Serial # B060496  Spec # 46264D, It is a 10 hsp K241
  • Chopperhed said thank you
#6 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted February 25, 2014 - 03:49 PM
As far as I can tell that makes it a 66 model year.
My first test when checking a charge system is to put a multimeter across the battery terminals with the engine running. It should read 13 volts or better at idle. Speeding up the engine should cause the voltage to go up a bit, till the regulator cuts the voltage.
I would check all connections to make sure everything is nice and clean before trying any tests. Grounds have to be clean too.
#7 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted February 25, 2014 - 10:53 PM
Try this link.. Follow step by step..  I have a 1966 chief 1000. I found it helpful.  Good luck!
http://www.farmallcu...stem Checks.pdf
Mike
Genoa,IL
#8 GreggHarris OFFLINE
GreggHarris
  • 5 Thanks
  • 5 posts
Posted February 26, 2014 - 08:07 AM
Thanks Mike, I read this through it seems it will be very helpful, I will have to run through it as soon as time permits.
