Here's What Came In The Shop Today And What Are These Parts
38 replies to this topic
#16 Sawdust OFFLINE
Sawdust
  • 4,569 Thanks
  • 2,849 posts
Posted February 25, 2014 - 09:14 PM
I think the only way plastic welding can work is to find a donor piece of the same or knowing exactly what kind you have. PW has my interest but not enough to give up fiber glassing & the use of epoxies & like mentioned reinforcing with metal. Keep us posted on what you do.
  • Gabriel said thank you
#17 Gabriel OFFLINE
Gabriel
  • 1,440 Thanks
  • 1,858 posts
Posted February 25, 2014 - 09:40 PM
The shield says ABS on it and the rod I used was ABS. I was able to mix the rod with the original plastic, but some of it seems to have burned( I'm not sure if it's the rod or both plastics). The instruction book that came with my welder, mentions only one kind of plastic that would turn slightly brown, and it wasn't ABS. It's hard to tell for sure if it's brittle, because I did such a small spot. When I tried to twist it, I thought it made some small popping sounds. Maybe it wasn't the weld. I think it may have air pockets too. The videos on the manufactures website make it look so easy. I would like to make a really good fix.
Edited by Gabriel, February 25, 2014 - 09:44 PM.
  • Sawdust said thank you
#18 Gabriel OFFLINE
Gabriel
  • 1,440 Thanks
  • 1,858 posts
Posted February 25, 2014 - 10:10 PM
Before I get all down about this(not that I should get down about it, it's only plastic), I have had some good success with a product called Plastaid. I used it to make a replacement tab on our JD LT155 lawn tractor and it's been going for 2 years or more and hasn't broke.
Edited by Gabriel, February 25, 2014 - 10:13 PM.
  • trowel and Sawdust have said thanks
#19 trowel OFFLINE
trowel
    Summer.
  • 4,819 Thanks
  • 4,533 posts
Posted February 25, 2014 - 10:29 PM
Gabriel, what is this Plastaid and how do you apply it ?
#20 Gabriel OFFLINE
Gabriel
  • 1,440 Thanks
  • 1,858 posts
Posted February 25, 2014 - 10:36 PM
Here's a link: http://www.plast-aid.com/index.html
I hope this link works.
#21 trowel OFFLINE
trowel
    Summer.
  • 4,819 Thanks
  • 4,533 posts
Posted February 25, 2014 - 10:43 PM
It worked, many thanks for that, i should try it.
#22 Gabriel OFFLINE
Gabriel
  • 1,440 Thanks
  • 1,858 posts
Posted February 27, 2014 - 10:35 AM
Oh, here's pictures.
#23 Gabriel OFFLINE
Gabriel
  • 1,440 Thanks
  • 1,858 posts
Posted February 28, 2014 - 01:05 PM
I looked in my plastic welding book and going by the recycling symbol on the hood pieces, they are either ABS mixed with another plastic, or not ABS at all. This is probably why it did not weld right, I was using the wrong welding rod.
#24 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted February 28, 2014 - 02:42 PM
Gabriel
if that plast aid really works it will have hundreds of uses. did you get yours on line or at the hardware store?
#25 Gabriel OFFLINE
Gabriel
  • 1,440 Thanks
  • 1,858 posts
Posted February 28, 2014 - 08:27 PM
I got mine online. I just used some today on the hood I'm repairing. I will let you all know how it goes.
#26 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted March 01, 2014 - 09:52 AM
Let us know how strong it seems to be
#27 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted March 01, 2014 - 09:55 AM
If that does not work , I have used a 3M product in the past called Structural Adhesive
its similar to a 2 part epoxy system, but a lot stronger, I have used on fiberglass, and plastic applications with good results.
Edited by rdehli, March 01, 2014 - 09:58 AM.
  • KennyP, sacsr and Gabriel have said thanks
#28 Gabriel OFFLINE
Gabriel
  • 1,440 Thanks
  • 1,858 posts
Posted March 01, 2014 - 09:57 AM
I will! I'm going to check it this morning.
#29 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted March 01, 2014 - 10:00 AM
lets hope that it works
#30 Gabriel OFFLINE
Gabriel
  • 1,440 Thanks
  • 1,858 posts
Posted March 01, 2014 - 10:01 AM
Thanks! I'm glad to know that!
