K321 Stator
10 replies to this topic
#1 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted February 24, 2014 - 07:07 PM
I have a jd314 and my question is. Has anyone tried or know if the engine stator can be changed with out removing the engine ?
Any help appreciated.
larryd
#2 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted February 24, 2014 - 08:06 PM
Hi Larry. The stator is behind the flywheel so you will need to pull the motor to get at it. It's not that big of a job to pull the engine. It's easier if you have some sort of lift or block and tackle to help hoist it.
  • trowel and boyscout862 have said thanks
#3 olcowhand ONLINE
  • 43,106 Thanks
  • 31,997 posts
Posted February 24, 2014 - 08:36 PM
Yep, as said, an engine pull is required.
  • trowel said thank you
#4 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted February 24, 2014 - 08:44 PM
Pull it, not too bad, really.
#5 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted February 24, 2014 - 08:49 PM
I was afraid of that. I started to pull it a couple weeks ago and so far I just raise the hood and look. II guess I just need to dive in and do it.
I do have rig that bolts to my bench to lift it out with and a roll around table to set it on.
This will be a good time to replace my wiring harness also, and install my dual pedal brakes  and if I decide to spend the money it would be a good time to install h2 hyd"s so I can power angle my snow blade. All I need is levers, h2 control valve, hyd lines and couplers. My blade already has the angle cyl.
Thanks
larryd
#6 olcowhand ONLINE
  • 43,106 Thanks
  • 31,997 posts
Posted February 24, 2014 - 08:52 PM
Well Larry, it was said it wasn't that bad to do, but it IS harder than just raising the hood!  :smilewink:
  • KennyP and WNYTractorTinkerer have said thanks
#7 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted February 25, 2014 - 06:00 AM
Larry, it sounds like you are talking yourself into a major upgrade/repair job. Have a good look at your motor mounts. The front ones are expensive but the back ones can be had for a reasonable cost and tend to be the first ones to go. It's a pretty tight fit to get the lines on those 2 channel valves. When I rebuilt my 317 last year I had some grief getting the lines back on. I was tempted to get a couple of rubber lines made so it would be a bit easier to run them but in the end I got them all back on and don't have any leaks.
#8 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted February 25, 2014 - 06:03 AM
Larry, I forgot ot ask why you need to get at the stator. It could be that you have a bad connection somewhere in the wiring rather than a blown stator.  Those connectors tend to develope bad connections after 30 years of dirt, heat, vibration and oil.
#9 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,503 Thanks
  • 6,158 posts
Posted February 25, 2014 - 07:25 AM
Unplug the regulator and test the two wire on the plug that go to the engine with an OHM tester..  (.1 to .2 OHMs per service manual section #8)  If there is no continuity then the stator is toast as you say..  BTW  My 314 had a busted motor mount when I got it apart..
#10 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted February 25, 2014 - 11:05 AM
When I got mine the PO had welded a broken mount directly to the frame.  Of course this melted the rubber mount and made it useless. It was a bit of a job to grind the mount off the frame and re drill the holes so I could replace it properly. The mounts are a problem area on these.
  • larryd said thank you
#11 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted February 28, 2014 - 08:55 PM
JDBrian, I agree totally about the mounts. I really yhink I need tout new mounts on mine.
larryd
