I bought another bolens.....
90 replies to this topic
#61 Nascar3244888 OFFLINE
Nascar3244888
  • 332 Thanks
  • 628 posts
Posted January 15, 2011 - 07:15 AM
i was just reading another post from buzz on the g10 and g12, is it true if it doesnt roll easy that the trans is bad? b ecause the 800 will roll easy then stop alittle then start going again, i couldnt tell if it was just slipping in the snow or what.....
#62 Nascar3244888 OFFLINE
Nascar3244888
  • 332 Thanks
  • 628 posts
Posted January 15, 2011 - 07:25 AM
Just sent away for those ebay items......Chrome Rings and new piston with the wrist pin and clips:yelclap:
#63 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted January 15, 2011 - 07:40 AM
Rays Mower Shop Pricing for S7D Parts
Piston: 62.65
Chrome Rings: N/A
Std Rings: 51.55
Wrist Pin: 15.02
Wrist Pin Clips: 3.29 each
Connecting Rod: 142.06
Gasket Set w/o seals: 48.71
Seals: 9.32 each
Bearings for Crank(comes with race):23.64 each
Carb Rebuild Kit: 46.79
:sensored:
Just as I suspected..... the prices keep going up! :wallbanging:
#64 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted January 15, 2011 - 07:41 AM
No, that was just a joke :D
When you push them It is common for some to roll a bit and then stop
#65 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Let us know when you get them in ! :thumbs:
#66 Nascar3244888 OFFLINE
Nascar3244888
  • 332 Thanks
  • 628 posts
Posted January 15, 2011 - 08:00 AM
Will do bud
#67 Nascar3244888 OFFLINE
Nascar3244888
  • 332 Thanks
  • 628 posts
Posted January 15, 2011 - 06:15 PM
found the clearence for the crank/rod.... we did a few times and would get anywhere between .002-.005 hope thats good
#68 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted January 15, 2011 - 06:21 PM
The manual says a clearance of .007-.015
It may be a little tight.... Is it possible you could have made an error? Does the connecting rod have any scratches or scoring? if so then it may be an indication of the clearance being too tight.
#69 Nascar3244888 OFFLINE
Nascar3244888
  • 332 Thanks
  • 628 posts
Posted January 15, 2011 - 09:16 PM
:wallbanging: I subtracted wrong hehehehe.....I am getting 1.365in, 1.362in or so for the rod, and the crank was 1.372 lol, that would indead make it within spec, duh....:wallbanging: long day, to much excitment with getting the 900 going i guess hehehehe....
#70 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted January 15, 2011 - 09:25 PM
Good to hear its within the specs
#71 Nascar3244888 OFFLINE
Nascar3244888
  • 332 Thanks
  • 628 posts
Posted January 16, 2011 - 02:46 PM
got the valves out, gave everything a real good cleaning, i will take some pics then, I noticed I have some pitting on the tappets and im not sure if there good or not. also i need a washer for the exhaust valve spring that is pitted and has some pin holes in it...that i can probably get at a hardware store. I will like i said take some pics then that way i can get some opinions....
#72 Nascar3244888 OFFLINE
Nascar3244888
  • 332 Thanks
  • 628 posts
Posted January 16, 2011 - 03:00 PM
If I need them for my s7d....will these from an s8d work?
WISCONSIN S-8D 8HP LIFTERS - eBay (item 220723943036 end time Jan-18-11 14:50:18 PST)
#73 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted January 16, 2011 - 03:28 PM
Yeah they will work
#74 Nascar3244888 OFFLINE
Nascar3244888
  • 332 Thanks
  • 628 posts
Posted January 16, 2011 - 03:46 PM
HPIM1910.jpg ok thanks, here are some pics of the valve train....
#75 Nascar3244888 OFFLINE
Nascar3244888
  • 332 Thanks
  • 628 posts
Posted January 16, 2011 - 03:54 PM
i think photos 4 and 7 best show what i need, i wish they were a little better quality, but #4 shows the exhuast tappet which has some pretty bad pitting compared to the other one...and #7 shows a little washer between the top of the spring and the other thicker...i want to call a spacer or something.....
