I bought another bolens.....
90 replies to this topic
#1 Nascar3244888 OFFLINE
Nascar3244888
  • 332 Thanks
  • 628 posts
Posted January 08, 2011 - 04:35 PM
:rocker:will post pics later.....i can tell you it needs a good amount of work but it looks decent.....oh and its an 800 model.
#2 awol OFFLINE
awol
  • 78 Thanks
  • 343 posts
Posted January 08, 2011 - 04:39 PM
Nascar you are just a Bolens machine, can't wait to see some pic'sLOL
#3 mjodrey OFFLINE
  • 2375 Thanks
  • 13481 posts
Posted January 08, 2011 - 05:17 PM
:ditto:
#4 daytime dave OFFLINE
  • 5488 Thanks
  • 6781 posts
Posted January 08, 2011 - 05:59 PM
Congrats on the new Bolens.
#5 Nascar3244888 OFFLINE
Nascar3244888
  • 332 Thanks
  • 628 posts
Posted January 08, 2011 - 06:13 PM
thanks everyone, i have a few questions....
1. There is ice in the cylinder and it is rusty and cant be budged( whether due to ice in cylinder or rusted fast i dont know)...I put pb blaster in the cylinder and am letting it soak...is there anything else i can do?
2. Starter Gen is the same way I have taken the back plate off and a quater of it is filled with ice. I have it sitting in a drain pain in the heated breezeway, will there be anything i have to do or should do once the ice melts?
3. This tractor was sitting for 2 years or so....They left it sit because they tried replacing the voltage reg. and had to "engergize it" and it hasnt run since trying to do this....what should I look for or what happened that would make it not run?
4.The head gasket was "replaced" with some orange rtv(lol), Could this make water seep in even though the hood was shut?
Pto is good, and everything else seems to be ok but i wont know until i can get it running. Gas Tank is Metal and is 7/8th full of really REALLY bad smelling gas, one tire is low on air however the other 3 are holding very well so far.
#6 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted January 08, 2011 - 08:00 PM
Congratulations on your new addition!!!!! :dancingbanana:
I cant wait for some pictures!!!
As for the water in the cylinder.... If it got in the cylinder then there is a good chance the water seeped below into the crank case.... You may want to play it safe and possibly take the engine apart and see what the inside looks like...
#7 Nascar3244888 OFFLINE
Nascar3244888
  • 332 Thanks
  • 628 posts
Posted January 08, 2011 - 08:42 PM
I was wondering if i should, if its anything like the starter gen. i wouldnt be surprised, I just hope I can fix it. lol, this would be my first wisconsin engine teardown lol, souds exciting....
Is there anything I can do about the rust on the cylinder wall above the piston? its close to bdc on the intake stroke and i already have the engine removed....that was the first thing i did....Ps. They had the muffler on this thing facing straight up like a stack and it is also 1/4 to 1/2 filled with ice right into the block......
Edited by Nascar3244888, January 08, 2011 - 08:45 PM.
forgot to add something
#8 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted January 08, 2011 - 08:51 PM
From your description so far it seems like the best thing to do is to be safe and take apart the engine to inspect it.
Depending on how badly the bore is rusted you may be able to just lightly hone out the cylinder.
#9 Nascar3244888 OFFLINE
Nascar3244888
  • 332 Thanks
  • 628 posts
Posted January 08, 2011 - 09:11 PM
one can only hope, never honed a cylinder....although i do have a "3 leg" stone hone for a drill i believe
#10 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted January 09, 2011 - 08:58 AM
Yeah, Thats what I use
#11 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted January 09, 2011 - 09:06 AM
So .... Where are the pics! ?
:picsoritsnotyours:
#12 Nascar3244888 OFFLINE
Nascar3244888
  • 332 Thanks
  • 628 posts
Posted January 09, 2011 - 09:51 AM
:picsoritsnotyours:
lol, patience.....i got all the accessories of the engine as well as the pulley, working on the flywheel now....theres a puddle of water in the pan where the starter gen was sitting too lol, i will take some pics after i warm up a little.....i also want to get the serial number off the shroud and find out the year
Edited by Nascar3244888, January 09, 2011 - 09:53 AM.
#13 Nascar3244888 OFFLINE
Nascar3244888
  • 332 Thanks
  • 628 posts
Posted January 09, 2011 - 10:12 AM
Serial Number Found!
Produced Year: 1963
Produced Month: January
Engine Model: N/A
#14 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted January 09, 2011 - 10:14 AM
Is the ID plate still on the body of the tractor?
Most likely its gone....
#15 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted January 09, 2011 - 10:15 AM
Produced Year: 1963
Engine Model: N/A
Is it an S-7D or S-8D?
