How To Power A Fel On Ariens Gt 17
4 replies to this topic
#1 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted February 23, 2014 - 03:37 PM
Im looking for suggestions on how to power a front end loader im building for my gt 17
#2 2broketrucks OFFLINE
2broketrucks
  • 1 Thanks
  • 6 posts
Posted February 23, 2014 - 06:13 PM
If you mean what size hydraulic pump, I seen a guy on YouTube use a 5gpm gear pump attached to his front pto shaft . I have been searching everywhere in how to attach it. That is why I joined this site:)
#3 warren OFFLINE
warren
  • 59 Thanks
  • 46 posts
Posted February 23, 2014 - 06:28 PM
You'll need to power a separate hydraulic pump to operate the loader.  On my 1st tractor I used a cessna pump that was belt driven and mounted below the the engine.  On my GT20 I'm using a 6 gpm pump that I purchased from Bailey Hydraulics and by modifying  an adaptor from surplus center, I'm running it directly off the engine.  I did need to notch the front of the tractor frame  to allow enough room.  If you check the pictures of my GT20 under the discussion "GT20 with turning brakes and foot control upgrades" and look closely at the pic of the front of the tractor you can just make out the pump and adaptor.  It would be easier to run it via a belt but I was worried about side wear on the pump bushings.  On my 1st tractor that I mounted this loader onto, I didn't have PS.  That was a chore to operate with a load.  I ended up adapting a PS set up from a JD 318.  Good luck.
#4 Wm McNett OFFLINE
Wm McNett
  • 126 Thanks
  • 169 posts
Posted February 24, 2014 - 08:32 AM
The Jonson Loader on my GT17 has a belt driven pump off the front PTO.
Ariens 831021
http://gardentractor...ont-end-loader/
Edited by Wm McNett, February 24, 2014 - 08:37 AM.
#5 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted March 03, 2014 - 02:11 PM
Thanks guys i think i will go with a belt driven pump does anyone have a picture of the mounting bracket used
