Cub Original Tail Light Mount?
10 replies to this topic
#1 searstractorfan OFFLINE
searstractorfan
  • 122 Thanks
  • 158 posts
Posted February 22, 2014 - 08:07 PM
I've asked where the tail light mounts on another forum and no one can tell me for sure where it goes.. I've seen 2 different places of it's placing. Anyone got one on theirs and can say for sure?
#2 hamman ONLINE
hamman
    Homelite Owner Extraordinaire
  • 6,616 Thanks
  • 2,913 posts
Posted February 22, 2014 - 08:43 PM
cubcadettaillight.PNG   Kind of like this one?  I did a search and this is what I found. Hope this helps.    Roger.
#3 searstractorfan OFFLINE
searstractorfan
  • 122 Thanks
  • 158 posts
Posted February 23, 2014 - 09:32 AM
Lol ya that's one of the pics I got showed on the other site... Also seen one with it over by fender..
#4 Dane in PA OFFLINE
Dane in PA
    Permanent Lurker
  • 552 Thanks
  • 616 posts
Posted February 23, 2014 - 09:40 AM
It depends whether or not you have a 3-pt.  If it's centered, it will be in the way of the lift and opt. spring assist.
#5 searstractorfan OFFLINE
searstractorfan
  • 122 Thanks
  • 158 posts
Posted February 23, 2014 - 07:34 PM
Ya no 3pt for me lol fenders yes! Once I get the mounting plate... I'll have to dig up my tail light, so I can see which while it uses...
#6 searstractorfan OFFLINE
searstractorfan
  • 122 Thanks
  • 158 posts
Posted February 24, 2014 - 05:37 PM
Here's the light, lens is good too! Is that the original mount? ImageUploadedByTapatalk1393281433.301087.jpg ImageUploadedByTapatalk1393281446.729004.jpg
#7 Jlaws OFFLINE
Jlaws
  • 556 Thanks
  • 368 posts
Posted February 24, 2014 - 10:21 PM
Yes that's the Original mounting bracket .
The slightly larger middle hole is for mounting it to one of the seat spring plate bolts .
The two outer holes were used for the later narrow frame cubs with fenders , and it was mounted to the fender which had two matching holes .
Edited by Jlaws, February 24, 2014 - 10:34 PM.
#8 searstractorfan OFFLINE
searstractorfan
  • 122 Thanks
  • 158 posts
Posted February 25, 2014 - 11:25 AM
Ah! Thanks glad to know!! Just gotta get the fender mount plate and I'm set to mount light and make it look good!!
#9 Jlaws OFFLINE
Jlaws
  • 556 Thanks
  • 368 posts
Posted February 25, 2014 - 12:29 PM
OK , now I'm confused ....I thought the above picture was your light and bracket  ??
Do you have a similar light and no bracket , or do you plan on buying fenders ?
I wish you had a front view of that light lens as they made very similar Grote lights for other IH models like the 154 184 etc.  lowboys .
Does the lens have 2 or 3 screw holes ?
Original round fenders do not have mounting holes for that light , it still gets mounted to the seat bracket .
I guess you could mount it to the round fenders by drilling holes , but that's usually frowned upon by the IH purists .....LOL
First picture is of Grote light mounted on my 100 with round fenders ,  attached to one of the fender bracket mounts .
Second picture is of my 122 with square fenders and factory two holes in fender .( Its the same as the 100 light and bracket . )
Third  picture is the 3 hole Grote lens and light that was usually found on IH lowboys ( its very similar to the two hole and uses similar brackets.)
Its supposedly a later version of the Grote light .
Sorry for the picture quality , but the 122 was buried and I had to stand on my head to get the picture .....LOL
#10 searstractorfan OFFLINE
searstractorfan
  • 122 Thanks
  • 158 posts
Posted February 25, 2014 - 04:11 PM
Sorry I have the light and bracket(pictures) and have fenders gotta get the pan that the fenders mount to and paint light and fenders at same time and stick them all on the tractor..
#11 searstractorfan OFFLINE
searstractorfan
  • 122 Thanks
  • 158 posts
Posted February 25, 2014 - 04:13 PM
