Electric Actuator Dump Cart?
4 replies to this topic
#1 grnspot110 ONLINE
grnspot110
  • 4,323 Thanks
  • 2,696 posts
Posted February 21, 2014 - 09:09 AM
I'm thinking about putting an electric actuator on my beefed up Sears dump cart:
Has anybody here done this?  If so, what size actuator did you use?  Any pics of your mounting?
My tongue is already beefed up:
I plan to put a plate under the bed for the lift bracket.
Any good ideas?  Thanks!  ~~  Lowell
  • hamman said thank you
#2 boyscout862 OFFLINE
  • 13,550 Thanks
  • 9,427 posts
Posted February 21, 2014 - 09:20 AM
Burdens Surplus Center has lots of choices. I would mount it in the front the way that most big dump trucks are. Take pics to show us what you come up with. Good Luck, Rick
  • grnspot110 and hamman have said thanks
#3 KennyP ONLINE
  • 40,886 Thanks
  • 47,094 posts
Posted February 21, 2014 - 09:52 AM
What is the distance from the tongue to the bed when It is dumping? That would tell you how much travel is needed. On my winch operated dump trailer, I have a 3-ton electric winch on it and it has a challenge when it is full of damp dirt!
#4 grnspot110 ONLINE
grnspot110
  • 4,323 Thanks
  • 2,696 posts
Posted February 21, 2014 - 12:07 PM
Burdens is where I get most of that kind of supplies!
It will be a while before my shoulder heals enough so I can work on anything like this, but my mind (such as it is) wants to do something.   :D   ~~  Lowell
#5 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted February 21, 2014 - 05:57 PM
Sounds like a great project Lowell. I had a steel JD 10 cart at one point and put a ball hitch on it and stiffened the tongue in a similar way to what you've done. It would have been nice to have an electric dump on that cart. I used it to load and dump/spread 2 tandem truck loads of crushed rock back in 2005 when we built most of our back yard trails. All done with a shovel and rake.
