Painting Aluminum
15 replies to this topic
#1 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted February 20, 2014 - 09:31 PM
I need some help guys. I am currently restoring an aluminum serial tag for a good friend of mine, but for some reason, the black spray paint isn't sticking. I have never had this problem before, so it's rather irritating! I was thinking about trying to bake the paint on, but I'm not sure what temperature to use, and I'm not sure if the aluminum will hold up to the heat. I've baked enamel paint to steel parts before, but never aluminum, especially aluminum this thin. The tag is off a hard to find tractor, so I have to be careful on what I do so that I don't ruin it. I'm sure my friend would be forgiving, but I don't want to travel that route if I don't have to.
This tag had some deterioration to it, and the lettering and border doesn't sit real high, so I can't apply to many layers of paint. I must keep the paint finish below the high spots of the lettering, in order to scrape the lettering clean. After the first coat of black, it didn't turn out real bad (the second picture) but it didn't suit me. I applied another thin coat of black, but now when I try to scrape off the paint from the lettering and the borders, the paint just peels or flakes off paint from where I don't want it to be removed. I have been letting the paint dry for at least three days. After painting the tag, I lay it on our radiator heaters so that the heat helps the paint cure faster. After the third day, I rinse the tag with warm water, dry it, let it sit over night, then start scraping. I don't understand why I'm having so much trouble with this one, as I never had this type of problem before.
Any and all help would be greatly appreciated.
Troy
  • hamman, IamSherwood and oldedeeres have said thanks
#2 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,616 Thanks
  • 2,913 posts
Posted February 20, 2014 - 10:36 PM
I think you have to etch the aluminum first. Now I'm not sure what to use on aluminum to etch it that will not distort or deform the aluminum and the stamped numbers. You might try googling, etching aluminum for painting, next, you might have to use a paint or ink for aluminum. I'm just reaching way back into my old mind and remembering from about a hundred years ago. My dad was doing nearly the same with some id tags fro furnaces back in the 70s and I don't remember exactly what he had to do.  Hope this helps a bit. Good luck. Let us know what happens.      Roger.
  • johndeereelfman, Arti and oldedeeres have said thanks
#3 MH81 OFFLINE
  • 29,979 Thanks
Posted February 20, 2014 - 11:48 PM
It really sounds like aluminum oxide. It can start pretty fast on some aluminum.
Probably not a situation where you can etch or sand heavy to get rid of it, if it were mine I would probably take it all off, clean with SOS or something, clean again, acetone wipe, and immediately paint it.
I see there are sealant/primer products for aluminum airplanes, they all require sanding tho.
  • hamman and johndeereelfman have said thanks
#4 jabelman OFFLINE
jabelman
  • 2,326 Thanks
  • 1,642 posts
Posted February 21, 2014 - 05:50 AM
Napa auto sells self etching primer in a rattle can. You have to have aluminum really clean for the primer to "stick"
  • hamman, johndeereelfman and HANKG have said thanks
#5 Alc ONLINE
  • 7,345 Thanks
  • 7,633 posts
Posted February 21, 2014 - 06:21 AM
Would the black paint they sell for gas grills work ? Though it's flat you would be able to bake it on as high as your oven goes .
http://www.homedepot...78830/202315061
#6 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted February 21, 2014 - 06:42 AM
I'll have to check this out on Saturday. Hopefully a thin layer of primer will work, as I can't apply a real heavy coat. Thanks for the tip!
  • hamman and IamSherwood have said thanks
#7 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted February 21, 2014 - 06:45 AM
Al, I did give this a thought already, and that was the thinking behind my baked on question. I think the paint would be fine, but I'm concerned about the thin aluminum curling or warping due to the heat temperature.
  • Alc, hamman and IamSherwood have said thanks
#8 HANKG ONLINE
HANKG
  • 6,610 Thanks
  • 3,534 posts
Posted February 21, 2014 - 03:37 PM
If all else fails you could have a repo sticker made and stick it to the tag just a thought.
#9 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted February 21, 2014 - 05:36 PM
Thanks Hank, but no Thanks. On a hard to find tractor such as this one, a decal replacement just won't do. I'll get something figured out, and make this tag look good somehow.
  • IamSherwood said thank you
#10 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted February 22, 2014 - 10:13 AM
Decal works great on mine.
#11 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted February 23, 2014 - 07:11 AM
Does your oven go over 800° ? If not don't worry about it warping or melting that's for sure. But the paint might not like it that's already on it.
#12 Sparky OFFLINE
Sparky
  • 1,298 Thanks
  • 1,892 posts
Posted February 23, 2014 - 10:19 AM
Unfortunately the batch of aluminum may have had impurities or other defects originally . Small tests of etching are needed .
My fathers job was in remelt at a large ladder company and required testing and additives to skim impurities . Good luck to you Troy . If anybody can do it , you can .
  • MH81 and johndeereelfman have said thanks
#13 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,467 Thanks
  • 5,625 posts
Posted February 23, 2014 - 08:48 PM
What about using a Black Permanent Magic Marker. ???
#14 IamSherwood OFFLINE
  • 8,395 Thanks
Posted February 23, 2014 - 08:50 PM
Zinc chromate primer is used to prime aluminum in marine environments.
#15 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted February 23, 2014 - 09:03 PM
I might have to investigate this Will. I'll also have to see if my friend will want me to use this on his tag, and take the chance of possibility of ruining it.  :smilewink:
