Taillight Wiring
4 replies to this topic
#1 thadscub OFFLINE
thadscub
  • 73 Thanks
  • 86 posts
Posted February 20, 2014 - 01:58 AM
hi guys i am in the process of tidying up my taillight wiring on a cub cadet 122 no where to hold the wire what should i do
thanks thad
  • A.C.T. and Bill 76 have said thanks
#2 Bill 76 ONLINE
Bill 76
  • 1,930 Thanks
  • 1,189 posts
Posted February 20, 2014 - 03:14 AM
There is a stick on tab that you can slide a wire tie through to secure your wiring.I have used them with some success,make sure you clean the surface good.
I don't recall what their called but the ones I used are about a inch square made out of some kind of plastic,the surface must be flat where you stick em.
I think I got them at NAPA ,A good hardware should have them,you can get them on line also.
You might want to put your wires in some split loom to protect them and keep em bundled together.
Adle clamps work great-----But you have to drill holes to bolt them on-------And some day you may regret drilling them holes in your GT
Bill
#3 KC9KAS ONLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted February 20, 2014 - 05:14 AM
They look like this...
#4 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted February 20, 2014 - 06:06 AM
Those will work but they need to be the ones that are designed for outdoor use. If you get them at Napa or another auto parts place they should work well. If it's out of sight you could also add some hot melt glue around the edges to help keep it on there.
#5 MH81 OFFLINE
Posted February 20, 2014 - 07:48 AM
I have used copper tubing a couple of times on stuff. It's easy to bend into a shape that suits and you can run it until you find a place you can attach it with holders under a bolt at both ends. Don't know how that would work on a cub but its a thought.
  • JoeMopar said thank you
