Options For New Heart In Jd400
122 replies to this topic
#106 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
Posted April 26, 2014 - 07:52 PM
Thanks guys, hes been a blast to hold and recall the good times and all the tractors we are going to restore
baby jon
  • Utah Smitty and twostep have said thanks
#107 Utah Smitty OFFLINE
Utah Smitty
  • 1,713 Thanks
  • 1,793 posts
Posted April 27, 2014 - 08:12 PM
baby jon
Babies are wonderful... but then they grow up to be teenagers... :D  (Just kidding!!)
Smitty
#108 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
Posted April 27, 2014 - 09:25 PM
Ok, moving on. I'm looking into what fuel delivery system I want to run.
Option A, The faucet fuel pump seems to do a good job with the k532, but I'm looking into a decent pump. I'm going to install a smaller canister screw on filter base. I have done this with my truck, with a 2 micro and then a 5. Granted these smaller engines are a little more forgiving than my cummins.
I will run a 5 or 8 micron screw on filter and after market pump.
So, I'm guessing the system will provide at least 6psi supply to the inj. pump.
Option B
Use the standard faucet pump, and a regular style inline fuel filter
What's you thoughts?
Edited by Pager450n, April 27, 2014 - 09:39 PM.
#109 Utah Smitty OFFLINE
Utah Smitty
  • 1,713 Thanks
  • 1,793 posts
Posted April 28, 2014 - 04:01 PM
I'm out of my league on this, Ryan... I'm not sure what kind of pressure the injection pump needs--I fed mine by gravity when I had the K482... I would for sure put a fuel/water separator on it, though.
BTW, did you see the JD400 PTO on the Spokane Craig's List for $400.  I posted it under "Ebay, Craig's List, finds"
Smitty
#110 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
Posted April 29, 2014 - 12:20 AM
I did see your post. I was lucky enough when I bought my 400, it came with the pto, tiller and 4 way blade. I won't tell you how much, because it wasn't too much :)
By having the 35 a tiller and the pto, I really wanted to have some umph behind those teeth, hence the repower.
I'm gearing up this weekend to hopefully pull it out(532) and start putting the new heart back in.
#111 Utah Smitty OFFLINE
Utah Smitty
  • 1,713 Thanks
  • 1,793 posts
Posted April 29, 2014 - 10:36 PM
Cool!!  I should be able to help out at least part of the time if you want an extra hand.  What day you going to start?
Smitty
#112 Utah Smitty OFFLINE
Utah Smitty
  • 1,713 Thanks
  • 1,793 posts
Posted April 29, 2014 - 10:37 PM
You're going to have to let me in on some of your acquisition skills, there, Ryan!!  I don't mean let me get something you want, but let me know if you come across something I might want!!
Smitty
#113 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
Posted May 10, 2014 - 09:05 PM
Ok, was able to get something done for the 400.  I took my radiator that was 15"x13" screen face, and my fan that I picked up.
This is how it was looking before tonight.  It needs a decent shroud for the fan and control of air flow.
Later today, I took the plasma cutter and some 14 guage tin and made a good looking shroud.
And this is how it looked with the fan.
#114 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
Posted May 10, 2014 - 09:09 PM
Finished product.
other than the welds not looking too hot (ran out of sheilding gas) , it mounted up nicely and has plenty of CFM through the radiator.    I cut the input of the radiator becaues it was at a 90 degree facing out.  I am going to braze it monday to a strait shot towards the engine.
  • olcowhand, Cvans and twostep have said thanks
#115 Utah Smitty OFFLINE
Utah Smitty
  • 1,713 Thanks
  • 1,793 posts
Posted May 11, 2014 - 09:37 PM
Looking Good, Ryan!!  Now, we can get to work on the flywheel adapter.  If you'll measure the inside of yours, I 'll check to see if mine is the same... since at some time I'll need to do the same thing for mine.
Smitty
#116 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
Posted May 12, 2014 - 03:47 PM
Sounds good to me Steve, id like to get this diesel into the jd and burn some fuel.
#117 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
Posted May 23, 2014 - 05:43 PM
Moving closer to the day!  I received three u joints from Baileynet.com, following a post on WFM about a two piece driveshaft.
 Started out with two 1" id u joints and one 3/4" id
Pressed the two apart
next, reassembly
finished, I now have two of the 1" by 3/4" ujoints.  Maybe use one for a wood chipper project.
  • olcowhand and Cvans have said thanks
#118 Utah Smitty OFFLINE
Utah Smitty
  • 1,713 Thanks
  • 1,793 posts
Posted May 23, 2014 - 10:52 PM
You're getting there, Ryan!!!  Hopefully we can get the adapter turned next week and we can get past these preliminaries and actually start putting a  new engine in your JD400.
BTW, let me know what you want for the K532 you pull out...
Regards,
Smitty
#119 Cvans ONLINE
  • 7,311 Thanks
  • 6,393 posts
Posted May 24, 2014 - 08:52 AM
Your doing nice work and I'll bet you find a use for the other U joint down the road. Thanks for the photos.
#120 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
Posted May 28, 2014 - 08:47 AM
Continuing forward.  I ordered a hydro cooler from a 318, this way it will saddle the driveshaft and get rid of the boxy 400 stocked cooler.
checking (roughly) the dimensions on the dash tower for the 400 and the 318 cooler is 9" across, and would fit inside.
I do have a pile of "parts" ready to go into the 400.  Im really hopeing to start monday.
  • HowardsMF155 and Cvans have said thanks
