My "new" "attachments" /snow Pictures
13 replies to this topic
#1 TAHOE ONLINE
TAHOE
  • 8,298 Thanks
  • 5,800 posts
Posted February 18, 2014 - 10:01 AM
I can't believe I'm going to type this, but...... Alan was right :wallbanging:  :poke:  :D  when he told me in an older thread I needed and would love tire chains for plowing my gravel drive.
I found a set in my dad's barn when I cleaned out this fall, they have probably been hanging there since he bought the HB212 in 1971. I brought them home and decided to see if they would fit my Sears. They were just a little long ( my Deestones are smaller diamater than a true 23" tire) but I was able to get then somewhat tight. I had to tighten a couple times during use as they wanted to slip sideways, but the last tightening seemed to do the trick.
Man, what a difference on the gravel drive. I never got stuck this go around ( we got 4-5") and I could back up the drive with out spinning...wonderful! I don't like the thump, thump, thump on the concrete drives, but I can live with it.
Ok, so you have to read this in a Jeff Foxworthy voice.....
" If you ever used electrical wire as chain tensioners on you garden tractor,  yyyooouuuu might be a redneck" :D
Here is mom's drive plowed. I sure am glad for this warm up this week, I have no where left to put this stuff. Gonna have a lot of gravel clean up come spring though. Could've pushed higher if not for the back blade stopping me.
This hill is a solid sheet of ice today. Thawed some yesterday with rain up till dark, then refroze. Backing down this morning, Tahoe did 180* spin, I just put in drive and pulled out :wallbanging:
You are turning while going down the hill, one you break over the top of hill, you are already in a turn, just hold on!
The neighbor's drive, probably 200-250', looks shorter in pic. Two little old ladies live back there have a little 1 bedroom house behind that garage on a hill, their nephew owns it and doesn't plow so I try to keep it clean so they can at least get in and out. It was rough plowng Saturday as there was deep frozen ruts from the previous snow I didn't get plowed.
  • daytime dave, Gtractor, MH81 and 10 others have said thanks
#2 KennyP ONLINE
  • 40,874 Thanks
  • 47,091 posts
Posted February 18, 2014 - 10:07 AM
Glad the chains are working for you! Get some bungee's for them.
  • TAHOE said thank you
#3 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted February 18, 2014 - 10:42 AM
Looks Good !!  Now a bit of caution, Picture #2 demonstrates the scenario for a classic High Center. Hanging the front blade on top of the pile and wedgeing the rear wheels off the ground with the rear blade.
DON"T ASK ME HOW I KNOW! :smilewink:
  • Gtractor and TAHOE have said thanks
#4 daytime dave ONLINE
  • 4,963 Thanks
  • 6,596 posts
Posted February 18, 2014 - 11:19 AM
Your driveway looks adventurous when icy, that's for sure.  You are a very nice neighbor to plow out the old gals next door.   :thumbs:  :good_job:
#5 robert_p43 OFFLINE
robert_p43
  • 572 Thanks
  • 534 posts
Posted February 18, 2014 - 11:30 AM
You did a nice job there.  :thumbs:  Those adjusters work.   Anything to keep them from pulling against themselves, I guess.
#6 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted February 18, 2014 - 11:31 AM
I've got a 300ft gravel driveway with a hill and I have found that chains are a bigger help than a dif lock or even 4wd. Add some weight on the rear wheels and it's amazing how much you can push with a small GT
  • Alc and TAHOE have said thanks
#7 MH81 OFFLINE
  • 29,978 Thanks
Posted February 18, 2014 - 12:21 PM
Glad it wasn't bad advice. The traction increase is amazing, isn't it?
Nice pics. Really happy the 16 is earning her keep.
#8 Walkinman1 OFFLINE
Walkinman1
  • 770 Thanks
  • 589 posts
Posted February 18, 2014 - 12:25 PM
2 link chains are a far smoother ride than 4 link chains so if you happen across a set, grab em. I think you'll be happy you did.
#9 MH81 OFFLINE
  • 29,978 Thanks
Posted February 18, 2014 - 12:31 PM
Yep, absolutely. I just watch for extra chains and then I can tear them apart if I ever need to. You could take two sets and make one two link set.
#10 classic ONLINE
classic
  • 5,631 Thanks
  • 2,345 posts
Posted February 18, 2014 - 12:43 PM
Great to see another Sears getting the job done! I put 23 8.50 12 ags from my Suburban 12 with shortened 23 10.50 12 tire chains on my SS/18. The narrower tires work better with the plow and the sears snow blower. I guess my snow blowers were meant for the earlier Suburbans with the narrow tires. I have absolutely no complaints!
#11 TAHOE ONLINE
TAHOE
  • 8,298 Thanks
  • 5,800 posts
Posted February 18, 2014 - 02:12 PM
But look how fashionable my blue wire is :smilewink:
Yeah, I thought about that, but I think I go slow enough I don't ramp up on it and the blade makes me lose traction before I get too high.
I have loaded ags and 33# wheel weights. Want to load down back blade, but then I couldn't lift it with the manual arm, that would necessitate and electric lift.
Yep, she is a good worker. She gives me a hiccup every know and then like the ignition last week, but she keeps on ticking.
Yea, I have 2 link for my little craftsman, but don't use the blower on it anymore so they just hang. I could cannabalize them, but cross links maybe too short. If I ever come across some extras I will surely grab them.
Now.....I need front traction, turn wheels on snow or ice and I just keep going straight. Found a local guy selling 3 Ribs, need to pick me up a set.
#12 farmerall OFFLINE
farmerall
  • 2,211 Thanks
  • 1,480 posts
Posted February 18, 2014 - 03:21 PM
You could do what my brother did. He had the same issue and he found a cheap set of snowblower chains to use on the front tires of his Allis Chalmers.
#13 Walkinman1 OFFLINE
Walkinman1
  • 770 Thanks
  • 589 posts
Posted February 18, 2014 - 05:24 PM
Front tire chains work well, the P.O. of my Sears had a set that came with when I bought it. One of them broke a cross chain though and I haven't repaired it yet but I need to get to that, I miss having them on there.
#14 Sawdust ONLINE
Sawdust
  • 6,154 Thanks
  • 3,548 posts
Posted February 18, 2014 - 08:11 PM
Looks good Marty & thanks for taking care of the little ole ladies. We're having a major melt down as well....water & ice everywhere.
