Ohio Steel Fabricators
6 replies to this topic
#1 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted February 15, 2014 - 03:05 PM
Can somebody tell me when Ohio Steel Fabricators went out of business, any info would be great.  What else did they make.  I own a sleeve hitch plow single gang disc plus lawn spike tooth aerator.   My Ohio plow is a little heavier than my brinly plus I think it plows nicer.
  • Jack said thank you
#2 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted February 15, 2014 - 03:08 PM
What were there primary colors of implements .  All that I can find is a deep green for the spike tooth , the plow and disc were an off white with green decals
#3 Jack OFFLINE
Jack
  • 1,290 Thanks
  • 857 posts
Posted February 15, 2014 - 03:41 PM
I had a yard roller that was red. I do not know anything about the company.
Ok, did a google search and found this http://www.ohiosteel.com/
Edited by Jack, February 15, 2014 - 03:44 PM.
  • olcowhand, drbish, Littledeere and 1 other said thanks
#4 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted February 15, 2014 - 04:27 PM
Thank you... that is the same address that's on my decals I"'ll get in touch with them .  Thank you.
#5 Littledeere OFFLINE
Littledeere
  • 1,650 Thanks
  • 1,483 posts
Posted February 15, 2014 - 06:10 PM
I know they had red, white and green I thought I had put a brochure on here but must not have I have 2 or 3 I will put on keep a watch out
and looks like black also
Edited by Littledeere, February 15, 2014 - 06:52 PM.
  • MH81 and drbish have said thanks
#6 OldBuzzard ONLINE
OldBuzzard
  • 7,026 Thanks
  • 4,792 posts
Posted February 15, 2014 - 06:47 PM
In most of the pics I've seen of the Ohio Steel plows, they were red.
My Ohio Steel Sleeve hitch for the Bolens tube frames is Red and the decal is in white and green..
  • Littledeere and boyscout862 have said thanks
#7 jpackard56 OFFLINE
jpackard56
  • 1,837 Thanks
  • 1,434 posts
Posted February 15, 2014 - 08:38 PM
Ohio Steel is alive and well in Columbus, Ohio. Facilities on Broad Street and Ferris Avenue. They no longer produce plows or 3 point tool bars. They have some of the tool bars on display in all the major full size tractor colors from the 1950's.  But they still do rollers, sweepers,carts/wagons for Gt's. They also make trailers including the orange ones that you can rent at Home Depot and some other items including plastic pipe and bridges.(the kind we drive on).
  • MH81, drbish, Littledeere and 2 others have said thanks
