Briggs Charging System Damage?
3 replies to this topic
#1 thom OFFLINE
thom
  • 339 Thanks
  • 244 posts
Posted February 14, 2014 - 11:03 PM
Briggs & Stratton engines with the charging system under the flywheel , (not ones with starter/generators) will run if boosted with a battery or a battery charger. Some have recoil starters and can be started that way. I have been told that starting and running one  with NO battery connected will damage the charging system. Anyone know if this is true or false? Thanks.
#2 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,982 Thanks
  • 4,410 posts
Posted February 15, 2014 - 12:04 AM
No it will not damage, just make sure the stator wire(s) are unplugged. The stator will still output voltage and if shorted will fry the windings under the fly wheel.
  • Alc and gopher have said thanks
#3 olcowhand OFFLINE
  • 41,092 Thanks
  • 31,402 posts
Posted February 15, 2014 - 09:15 AM
Larry is right, won't harm a thing.
#4 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted February 15, 2014 - 06:08 PM
What they said, the ignition doesn't need a battery, and the charge system doesn't care if there is a battery, so long as the charge wire doesn't short to something.
