So I Have An Idea Bouncing Around In My Empty Head
9 replies to this topic
#1 UncleWillie ONLINE
  • 14,597 Thanks
  • 8,324 posts
Posted February 14, 2014 - 07:45 PM
What is the strongest GT hydro transaxle? Don't care what brand, just looking for something stout.
And can I use wheel brakes with a hydro?
Edited by mybigwarwagon, February 14, 2014 - 07:47 PM.
  • Sal Mcc said thank you
#2 olcowhand ONLINE
  • 38,063 Thanks
  • 30,461 posts
Posted February 14, 2014 - 08:04 PM
I don't know which is strongest, but yes, you can use wheel brakes.  The hydro/diff's under the JD430 & Simplicity Sunstar are TOUGH units & come with individual drum brakes & 2 speed final.  MANY others have individual wheel brakes, but my head doesn't want to concentrate enough to remember all of them.  Oh, I will add these, being I own them, the Allis 620 & 720 have wheel brakes, and a VERY stout hydro & differential, 3 speed rear as a matter of fact.
#3 farmerall OFFLINE
farmerall
  • 2,191 Thanks
  • 1,471 posts
Posted February 14, 2014 - 08:53 PM
An IH built Cub Cadet rear end pretty strong too. You can find them in either gear drive or hydro drive. The gear drive ones are what most gt pulling tractors use.
  • Alc and sacsr have said thanks
#4 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,378 Thanks
  • 4,084 posts
Posted February 14, 2014 - 09:18 PM
Not sure about too many hydro's, heck, I only know about one (BMP's) Ford LGT145 but it in pretty beefy.
  • sacsr and Sal Mcc have said thanks
#5 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,334 Thanks
  • 1,519 posts
Posted February 14, 2014 - 09:45 PM
I know the hydro in the 990 is a 2 speed with 1 little brake disc behind it. Also the cubs used the dual brake setup on both the hydro and the gear drive. The super cubs have the hydro with turning brakes on them.
#6 skyrydr2 OFFLINE
  • 3,819 Thanks
  • 3,364 posts
Posted February 15, 2014 - 05:52 AM
Peerless 2500 series are what a lot of gt's use as well as the 2600 series too. The latter has a diff lock option both can use either Eaton or Sundstand hydro units .the 2500 series also had a standard shift option ( powerkings had them) .
#7 Sal Mcc OFFLINE
Sal Mcc
  • 104 Thanks
  • 112 posts
Posted February 16, 2014 - 10:16 PM
Wille, Interesting subject. I have bought an MTD 998 that i am currently in the process of getting it running. It is too early for me to tell because so far i have only briefly started it to check the hydro and lift. But from just looking at the appearance of it, It seems to be pretty beefy.
I may know a little more at the end of the week. I intend to take a day or two off work this week and try to get it going. But I am liking it so far. As a little plus (one of the main reasons i got it), it has a rear lift.
Is your plan confidential at the moment?
#8 UncleWillie ONLINE
  • 14,597 Thanks
  • 8,324 posts
Posted February 17, 2014 - 12:44 AM
Not confidential just unformed
#9 OldBuzzard ONLINE
OldBuzzard
  • 6,837 Thanks
  • 4,737 posts
Posted February 17, 2014 - 07:08 AM
The rear end of the Bolens HT23 is pretty danged stout.
It uses the Eaton 11 Hydro.
#10 trowel OFFLINE
trowel
    Summer.
  • 4,822 Thanks
  • 4,533 posts
Posted February 17, 2014 - 07:16 AM
That's what i was thinking too.
