Wheelhorse 518 Onan, wiring coil
#1
OFFLINE
Posted January 06, 2011 - 01:25 PM
Any help would be greatly appreciated, thanks in advance,
John
#2
OFFLINE
Posted January 06, 2011 - 01:38 PM
How many wires are there? What color are the wires? What model of Onan is this?
Brian
#3
OFFLINE
Posted January 06, 2011 - 01:46 PM
Have to keep it in the mountains because I have a meddlesome neighbor that doesn't like me to have any lgts in my yard, even though she can't see them and they don't bother her.
Thanks, I'll get back to you when I get all that info.
#4
OFFLINE
Posted January 06, 2011 - 01:56 PM
What mountains, I used to live out by Franklin,N.C.. Just got back from there visiting wife's family.I can problibly find the wiring layout for you if I knew what mdel Onan?
Brian
- jwilliams1130 said thank you
#5
OFFLINE
Posted January 06, 2011 - 03:12 PM
Thanks again for your offer and I will get back to you soon.
Edited by jwilliams1130, January 06, 2011 - 07:32 PM.
#6
OFFLINE
Posted January 06, 2011 - 04:34 PM
Garry
#7
OFFLINE
Posted January 06, 2011 - 05:10 PM
#8
OFFLINE
Posted January 06, 2011 - 05:18 PM
#9
OFFLINE
Posted January 06, 2011 - 06:31 PM
my tractor is a 518H. It has an Onan 18 h.p., should be around a 1988 model.
Getting confusing. In post #1 you said it was an Onan, then in post #5 you stated it was a Kohler???????
#10
OFFLINE
Posted January 06, 2011 - 07:00 PM
#11
OFFLINE
Posted January 06, 2011 - 07:34 PM
Thanks for catching that.
#12
OFFLINE
Posted January 06, 2011 - 07:42 PM
#13
OFFLINE
Posted January 06, 2011 - 08:28 PM
#14
OFFLINE
Posted March 01, 2011 - 03:09 AM
2. There are two wires going to the positive (+) terminal, one wire is red and goes to the ignition module, the other is yellow/black and comes from the PTO switch behind the PTO lever.
3. the ignition module is behind the flywheel (left side bottom of engine)
4. If it still does not start, run a jumper wire from the positive battery terminal (+) directly to the positive (+) side of the coil.
Kevin
