Vintage Snappin Turtle Mower - $80 (Niskayuna)
8 replies to this topic
#1 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted February 13, 2014 - 11:29 AM
This is a steal at $ 80, man i would like to add this to my Snapper collection.
http://albany.craigs...4281840346.html
  • hamman and Jack have said thanks
#2 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,436 Thanks
  • 2,860 posts
Posted February 13, 2014 - 12:10 PM
Neat machine!  I think I already told the story about using one of these when I was a kid mowing a large cemetary.   Many memories.  Looks like a good deal if it runs good.       Roger.
  • sacsr, trowel and Jack have said thanks
#3 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted February 13, 2014 - 02:15 PM
Anyone nearby?
Ben W.
  • trowel and Jack have said thanks
#4 glgrumpy ONLINE
  • 8,616 Thanks
  • 7,923 posts
Posted February 13, 2014 - 05:05 PM
Where's the wheels???  This one of those "floating" ones I've heard about?  Don't see how they worked being made of heavy metals, not like the later year ones that were light and plastic. None of them ever caught on. Must be a reason?
  • Jack said thank you
#5 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted February 13, 2014 - 05:20 PM
Two hard rubber lined cast iron wheels on the back behind the engine below the handlebars in the deck.
They did take off, very well made with the variable speed friction drive with reverse, all snowthowers us now, then Snapper did a revamp and started coming out with the high lift aluminum decks we all know so well now, the change from the above photo to the high lift type was to suck up the grass cutting it better and while cutting it which the old one did very well but also to blow into a bag mounted between the handlebars instead of off to the side the old one had, hence the snale shell look of the later decks.
Below shows a walk behind with the ''teeth'' which are missing/covered up on the CL ad and of Snapper's first riding mower, precurser to the Snapper Comet mower.
Edited by trowel, February 13, 2014 - 05:21 PM.
  • DB1 and Jack have said thanks
#6 Jack ONLINE
Jack
  • 1,290 Thanks
  • 857 posts
Posted February 13, 2014 - 05:28 PM
Somebody should snap that thing up!       :smilewink:
  • trowel said thank you
#7 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted February 13, 2014 - 05:50 PM
'Bout two hours from me. Should there be any kind of guard over the belt or did they come that way?
#8 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted February 13, 2014 - 06:10 PM
The early ones were open, would need the serial no off the deck and date code from the engine to conferm.
Missing the teeth from the front, as you see covered with plate, commonly done by owners.
  • LTD said thank you
#9 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted February 14, 2014 - 09:24 AM
Many of those Snappin' Turtles did not have the "teeth" on the front.  ....Many mowers were equipped with the adjustable-height plate on the front from the factory.
Edited by Bruce Dorsi, February 14, 2014 - 09:25 AM.
