Hydraulic Drive Issue Jd 345
drive hydraulic performance speed
6 replies to this topic
#1 leobeaudry OFFLINE
leobeaudry
  • 1 Thanks
  • 5 posts
Posted February 13, 2014 - 10:38 AM
I have a JD 345.
Over the past year or so, I've noticed a decrease in performance of the drive wheels.
As the unit warms up, the speed, power and responsiveness of the drive transmission go down.
Mower, tiller and snowblower are not affected, just the drive wheels.
When I changed the hydraulic oil and two filters, I experience a brief return to  "like new" performance  . . .  approx 10 min later . .  . back to slow.
Any ideas on what might be happening?
Thanks for any help you offer.
#2 bh115577 ONLINE
bh115577
  • 442 Thanks
  • 240 posts
Posted February 13, 2014 - 11:06 AM
I don't have the manual open but since the drive circuit is the only one having issues and you saw some short lived improvement with fresh fluid the relief pressure might be low. Many relief valves are adjustable, not sure about this one, but you'll need a pressure gauge and possibly a flow meter to set it correctly.
  • leobeaudry said thank you
#3 JDBrian OFFLINE
  • 9,593 Thanks
Posted February 13, 2014 - 11:47 AM
I'd check the drive belt condition and tension and the tensioner mechanism to make sure it's up to snuff. Those K series transaxles are pretty reliable. I think it's a K71 transmission and you may be able to find service info on the Tuff Torq site.
#4 olcowhand ONLINE
  • 36,869 Thanks
  • 30,149 posts
Posted February 13, 2014 - 12:06 PM
Yes, very much sounds like a belt issue.
#5 boyscout862 OFFLINE
  • 10,505 Thanks
  • 7,927 posts
Posted February 13, 2014 - 12:12 PM
Welcome to GTT. Relax and enjoy the site. We are all in this together. Good Luck, Rick
#6 leobeaudry OFFLINE
leobeaudry
  • 1 Thanks
  • 5 posts
Posted February 13, 2014 - 10:23 PM
Thanks so much!  Looks like I have some homework to do . . . will keep you all posted.
#7 Alc ONLINE
  • 5,919 Thanks
  • 6,887 posts
Posted February 14, 2014 - 06:55 AM
I'm not sure about your problem but on my 318 it wasn't going as fast figure it was old age , but when I was changing the hyd filter I noticed the linkage was worn a little , on mine it was a roll pin hole egged out , drilled it bigger and roll pin helped a lot ,
Also tagged with one or more of these keywords: drive, hydraulic, performance, speed
