Hone, Bore, Toss
38 replies to this topic
#31 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted February 23, 2014 - 06:35 PM
Well, it runs.  The carb is leaking but that is a later problem.  I have a carb kit (and a spare carb), it is just a matter of time.  I ran it for about 20 minutes at various speeds & then changed the oil (Mobil synthetic 10W30).  It was barely warm, but then it was about 32*F outside.  The oil contained lots of fine metal flakes/powder, just as was predicted.  Good to have the old girl running again.
While watching the video, I noticed that there was originally a "Waterloo 40" decal on both sides of the gas tank.  I wonder what they looked like.  Anyone have a photo?
  • Bolens 1000, trowel, Cvans and 2 others have said thanks
#32 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted February 23, 2014 - 06:37 PM
Sounds good
Not so sure I'd be using synthetic oil in these older engines though......
  • trowel and New.Canadian.DB.Owner have said thanks
#33 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted February 23, 2014 - 06:48 PM
I thought the synthetic might be better for the break in period.  If you think it will do damage, it I'll replace it.
Edited by New.Canadian.DB.Owner, February 23, 2014 - 06:48 PM.
#34 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted February 23, 2014 - 06:53 PM
I've heard from many people including dealers that synthetic should not be used in these older engines.
#35 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted February 23, 2014 - 06:54 PM
Sounds good
Sounds good.
SAE 30 non synthetic non detergent oil but these old winnies can tolerate different a lot, changing it out anyways so no worries with any damage.
You got to bed down the rings after a half an hour of running, before any hard loads, start small such as driving it around on flat land, after the 4 th hour you can start to add small loads, slowly break it back in.
  • boyscout862 and New.Canadian.DB.Owner have said thanks
#36 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted February 23, 2014 - 06:57 PM
No smoke, no bad noises, you did a great job :thumbs:
#37 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted February 23, 2014 - 07:17 PM
I could not have done it without the help of the folks on this great website!
  • trowel, boyscout862 and Gabriel have said thanks
#38 Cvans OFFLINE
  • 6,649 Thanks
  • 6,130 posts
Posted February 23, 2014 - 09:55 PM
That must have just about made you as happy as you've been in a while when you heard that start up. Nice job on the rebuild.
In the days when that engine was new non-detergent oils were common. I would strongly suggest that you not use them now however. Those old oils built sludge in engines at alarming rates. Engine life in automobiles was around 70,000 miles between overhauls and when torn down they were full of crud inside. The best thing that ever happened to oil to extend engine life was the addition of detergents .
As stated 30w would be good. Might be a little thick for this time of year but in the summer it should work fine.
#39 KennyP ONLINE
  • 38,417 Thanks
  • 45,945 posts
Posted February 24, 2014 - 06:23 AM
Glad you got it running. I would stay away from the synthetic oil. Good luck with it. Don't forget to torque the head bolts again.
  • trowel, Cvans, boyscout862 and 1 other said thanks
