John Deere 262
6 replies to this topic
#1 Traill95 OFFLINE
Traill95
    Traill95
  • 1,848 Thanks
  • 1,013 posts
Posted February 11, 2014 - 05:26 PM
At the place that I work they have a John Deere 262 with a 36' snow blower attached to it. It also has a canvas and plastic cab. It has been sitting in the same spot (indoors but not a heated area) and has not been run for a least 5 years and now they have decided to auction it off. Does anyone have any idea what it might be worth? It has a K series Kohler 17 hp engine with Electronic ignition. the production number is just a guess because it was too scratched up to read clearly.
The  # might be 10G282X037743* maybe.   I am thinking about bidding on it plus a Sears Industrial Bandsaw  and a bench grinder for sharpening tools for the lathe.
Any help on pricing the JD would be appreciated. :D
#2 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted February 11, 2014 - 05:46 PM
Have a look here. http://www.tractorda...eere-gt262.html
It says it is a Kawi 17HP. It's a fairly new tractor according to the data at the link. It won't give you prices but will give you a good description.
#3 Cat385B OFFLINE
    HAZMAT CAT
  • 13,989 Thanks
  • 10,009 posts
Posted February 11, 2014 - 07:25 PM
The blower will be a 38" or a 42". Either one is worth $400 if it works and has all its parts. The 42" might be worth a bit more in good condition. A 262 in good operating condition with a deck is worth $1,000 any day of the week here. The cab is worth $300 around here at the start of winter.
#4 Traill95 OFFLINE
Traill95
    Traill95
  • 1,848 Thanks
  • 1,013 posts
Posted February 11, 2014 - 08:04 PM
I had the hood open and looked right at the motor it is a Kohler 17hp  vertical shaft engine I believe it is a twin cylinder. I will double check tomorrow. I can't take pics of it because we are not allowed to have a camera in the plant. As far as that goes I am not even supposed to have my cel phone in there either.
#5 Traill95 OFFLINE
Traill95
    Traill95
  • 1,848 Thanks
  • 1,013 posts
Posted February 11, 2014 - 08:07 PM
It must be a 38 inch I didn't have a tape measure with me so used a piece of wire that was nearby to get a width to take back to the shop and measure.
Aas far as bidding goes I wasn't thinking of going much higher than 375 because I don't know if it still runs and don't think there are to many more people than me interested in it because it has sat so long.
Edited by Traill95, February 11, 2014 - 08:09 PM.
#6 Traill95 OFFLINE
Traill95
    Traill95
  • 1,848 Thanks
  • 1,013 posts
Posted February 11, 2014 - 08:11 PM
It doesn't have a deck. I think they bought it new without a deck but with the blower and cab on it.
#7 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted February 12, 2014 - 06:07 AM
It's certainly worth 375 with a blower and cab even if it doesn't run. assuming it was running when parked it should be relatively easy to get it going again given that it was stored inside.
