Celery Planter
9 replies to this topic
#1 MH81 OFFLINE
  • 29,978 Thanks
Posted February 11, 2014 - 04:51 AM
Not a GT or GT related, but interesting piece.
antique celery planter
http://erie.craigsli...4310859214.html
Here is a antique three wheel celery planter. Its one of a kind not alot of there out here. $1000
4404133119
  • Alc, hamman and Arti have said thanks
#2 HANKG ONLINE
HANKG
  • 6,589 Thanks
  • 3,527 posts
Posted February 11, 2014 - 06:07 AM
Is that a engine on that machine do you drive it ?
#3 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted February 11, 2014 - 06:52 AM
Wow! A Thousand Dollars. That's a lot of Celery!
#4 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted February 11, 2014 - 07:12 AM
Looks like a hit and miss to me that might be missing some parts.
Ben W.
  • hamman and trowel have said thanks
#5 DougT ONLINE
DougT
    Dog Approved
  • 7,108 Thanks
  • 5,075 posts
Posted February 11, 2014 - 08:10 AM
The engine is a Fairbanks Morse ZD, AKA salt block. It's actually a throttle governed engine. I don't see anything missing. I'm not sure if it was this one or another one used to be shown at some of the Ohio shows. The thing goes super slow and he was always winning the slow races with it. There is a town near me called Celeryville and there used to be a bunch of these out there. I'm not sure if these are factory built or if they made them special for their applications.
  • MH81, Alc and trowel have said thanks
#6 olcowhand ONLINE
  • 42,885 Thanks
  • 31,934 posts
Posted February 11, 2014 - 08:38 AM
Yuck, I hate celery!  But that machine is neat!
#7 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted February 11, 2014 - 09:31 AM
Well now that is just the ticket if your growing Celery!!  Neat Machine and I would like to see one in operation, since I'm not quite getting the concept?
I am assuming you sit on it and press the starts/sets into the ground?  Never have grown Celery and never even considered it.
Now I have considered growing asparagus as a market crop(more than I can eat) and have seen some pretty well engineered buggy's put together for that. There is an asparagus farm about 40 miles from me that has a converted Snapper Comet, set low enough to cut the asparagus spears while driving between the rows.
#8 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted February 11, 2014 - 05:51 PM
technically its a trans planter. You sit on the seat, a runner opens a furrow, you then either would have a mechanical chain that sets the plants or you would have to drop them in by hand. After that the rear wheel push and firm the dirt around the set. Some units would have also had a water dropping valve, hooked up to a 55gl barrel. I used to have similar machines when I planted tomato's and other root type plants. Since to does plant a Horticultural item, it would be fair to include it as GT equipment, and I think its pretty cool that one still survives.
  • JD DANNELS said thank you
#9 olcowhand ONLINE
  • 42,885 Thanks
  • 31,934 posts
Posted February 11, 2014 - 06:22 PM
Much like a tobacco setter, but they are pulled by a tractor, not self propelled.
#10 twostep OFFLINE
twostep
    Rockstar
  • 1,988 Thanks
  • 2,539 posts
Posted February 13, 2014 - 12:24 PM
Yup, we used to one that looked like this except it was a one row setter and pulled by a tractor. The mechanism was driven by ground engaging wheel though, looks like this one is the same way.
So who steers this thing?
