Snapper 1650 Gets A Diesel
lombardini 1650 snapper
36 replies to this topic
#31 olcowhand OFFLINE
  • 43,118 Thanks
  • 31,998 posts
Posted March 19, 2014 - 08:14 PM
I always thought it an odd OE system even with belts, as the 2 belts never could ride exactly even either.  Would have been better to have had fixed positions of shafts and a belt idler pulley to apply tension.  The odd angles caused premature wear to the shaft splines & couplers.
  • coldone said thank you
#32 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Posted March 20, 2014 - 08:42 PM
I think I have the drive system worked out now. I had mocked up everything before I bolted it tight and it all looked good. When i first cranked it up it ran good and the chain was tracking. Then it threw the chain and my sproket angles were off severly. I got time to mess with it today. The front bearing (swing arm) had locked in its mount. This is supposed to be a free floating self centering bearing. It was bound up tight and jamming up the whole works. I pulled the swing arm, front drive shaft and mid mount bearing. I swapped the mid mount bearing (new one) with the swing arm bearing (reused one) and I spent some time cleaning the reused bearing mount and got it free. Once I reinstalled everything it worked like it was supposed to. No binding and the angles were correct. I still want to tweak it a little more but I think I got it. Only hard work and time will tell.
  • KennyP and Cvans have said thanks
#33 propane1 ONLINE
propane1
  • 9,727 Thanks
  • 4,509 posts
Posted March 21, 2014 - 03:09 PM
The torque is about 31 ft lb at 2200 rpm. Didn't find the same engine for specs, but it was a two cylinder, 18 hp diesel, same brand name. i know it's useless information, but i like that stuff. Noel
#34 VICHARRIS OFFLINE
VICHARRIS
  • 102 Thanks
  • 56 posts
Posted March 27, 2014 - 09:39 PM
Well  Coldone, I green with envy. John Deere humour. I have been silently reading you progress in Lomardini diesel powering your 1650 Snapper.
Nice. Very nice.
Waiting for the arrival of warmer weather. As in Ottawa March 27th, there is still 3 feet of snow in our yard. Had some more snow today. Then, maybe nature ( will soon) will allow me to start, painting my Lomardini powered John Deere 316.  I am starting to get the itch and  new refreshing ideas of completing  my 1978 1650 MF Lomardini ( stalled for 2 years ). I will be using u-joints and a drive assembly to the hydro unit. And I am thinking of using a timimg belt assembly  ( near the engine ) instead of using the twin belts. To power the rear PTO shaft assembly. .....Cold weather allows plenty of time to think.
Thank-you
#35 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Posted March 28, 2014 - 05:43 AM
I hope it gets good and warm for you soon. I want to see your 1650 conversion. You did great with the JD.
#36 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Posted April 20, 2014 - 09:00 PM
Double tap
Edited by coldone, April 20, 2014 - 09:30 PM.
#37 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Update time. I think I am about 85% complete on the project. I have Painting, and some miscellaneous items and I am not sure I like the drive setup but I will be watching it.
Now that the majority of it is done, there are a few things I would do differently. If I would have relocated the Air cleaner, I could have made the frame shorter. It would only have been 6 inches longer, the same size as a regular 1655/1855. I think it would have been an easy swap in xx55 series. I would have also started out using the xx55 series drive shaft setup instead of trying to adapt the 2 piece 1650 shaft. Too many headaches.
Here are some pics of how she is now.
Edited by coldone, April 20, 2014 - 09:09 PM.
  • limebuzz, Cvans and FrozenInTime have said thanks
Also tagged with one or more of these keywords: lombardini, 1650 snapper
